Raped at Dealer!! - For New Battery
Rating: Thread Rating: 4 votes, 5.00 average.
Old 02-27-2010, 05:09 PM
  #76
socali.luv's Avatar
E55 AMG
You may have forgotten something...
I understand exactly how you feel right now, and how many people must feel. Here's the thing; dealerships, or ANY business for that matter, WILL nickle and dime you unless you are a well known client. The established relationship with that dealer is worth a lot more to them and to you than you my think. If you regularly service your car at one place with a specific advisor, they will ensure you are happy and not nickle and dimed, because more important to any MB Service Advisor than 2 hours of labor is a 100% follow up survey report. The same may be said for many other businesses. We see the end result of your situation, but did you take the time to adequately communicate with your service advisor before the final billing to ensure a good price and fix?
Old 07-19-2010, 01:03 AM
  #77
I Like Soup's Avatar
2003 E55 AMG
Yep, the last week or so of driving I've been getting the intermittent variety of the Workshop Visit Red Battery indicator. As it turns out, I went to Autozone to get my main battery checked out since it had been about 2.5 years since that one had been changed. The battery read 12.65V and the alternator was good. So, we checked the accessory battery under the hood and it read 10.33V. I just got that one in October '09 so I'll be getting that one replaced under warranty tomorrow!
Old 11-13-2011, 04:48 PM
  #78
GRAFH's Avatar
2005 E55 AMG
Has anyone found an alternate battery that replaces the aux FIAMM Italian battery? I mean 100% bolt in. Using the same OE battery connections with out modifying them?
Old 11-13-2011, 05:31 PM
  #79
Tibi's Avatar
03 Silver E55
Go to any battery place and they will be able to sell you one. I wasn't driving my car at the time so I took the batteries in, they took one look told me what the battery codes were, and I was on my way in 10mins.
These are not special batteries. I believe my replacement is a motorcycle battery. Exact same size, and terminals.
Old 11-14-2011, 08:11 AM
  #80
novae500's Avatar
W211
Battery below the air filter is similar to motorcycle batteries.
Old 11-14-2011, 10:48 AM
  #81
GRAFH's Avatar
2005 E55 AMG
Yes, I know it is similar to motorcycle batteries. I'm more worried about the special terminals it has. So far I checked interstate and optima and neither have a listing for the aux battery.
Old 11-14-2011, 01:28 PM
  #82
Tibi's Avatar
03 Silver E55
They are not special terminals. My old quad had the same terminals.
http://www.power-sonic.com/powersport_battery_types.php
If you cant pull the battery go to the dealer ask them what battery code is. Then go to a bike shop or atv shop and they will be able to sell you one.
Old 11-14-2011, 01:55 PM
  #83
W109 W211 6.2L's Avatar
2008 W463 G500, 2003 Terminator Cobra (710RWHP), 2012 S350 Bluetec, 2010 911 C4S, 2007 VRSCDX
I have had Oddessy batteries in the past and they are pricey but worth every penny. Not sure they offer one for the electrical but if they do thats what i will be buying, considering its much better than any Mercedes OEM battery.
Old 11-14-2011, 03:03 PM
  #84
Infiniti's Avatar
a unicorn tuned p30 e63
i went to walmart and bought one. 73 bucks.
Old 11-14-2011, 03:07 PM
  #85
chawkins2001's Avatar
2006 E55 AMG
Good info here guys.
Old 11-14-2011, 04:24 PM
  #86
GRAFH's Avatar
2005 E55 AMG
Optima does not make an aux battery for the amg.
Old 11-14-2011, 06:36 PM
  #87
Odyssey is not an Optima, its actually a better battery than an Optima from all the research I have done and seen. A standard Odyssey battery goes for around $300 while an Optima is around $200
Old 11-14-2011, 07:17 PM
  #88
Rmd45021's Avatar
2004 E500
Originally Posted by yeahdickey
___________________________________________
A54999 Electrical Misc Repair $262.50
4715 COT
1 211-541-00-01 Battery $184.90
1 Batt Batt Disposal 1.50
1 KY Jelly 0.00
1 Non-Consensual Sex 0.00
* 46618 AUX Battery Defective. Short Test Battery Control Module Reprogram Fault 9092 Aub Battery Defective. Fail Battery Test. Remove and Replace AUX Battery 2.0 Hrs
262.50 Labor + 184.90 Battery + 1.50 Battery Disposal = $448.90 !!!!!!!!!
*Fixed*
Old 11-14-2011, 10:56 PM
  #89
Shifter's Avatar
E55, SL63, ML550
Good point. They did fix it right? (not like you brought it in saying, replace my battery)
Originally Posted by Rmd45021
*Fixed*
Old 11-15-2011, 01:46 AM
  #90
Denroll's Avatar
'06 E55
^That was from 2008.
In the motorcycle world, people have had luck with genuine Yuasa batteries. I recently purchased a battery from a new company called Shorai that makes lithium based batteries that are amazingly compact and light. Their "weakest" battery still has an output of 102 CCAs (Cold Cranking Amps) and weighs a whopping ONE pound! They also maintain their charge for up to a year. I had a highly modified bike (bored, stroked, cammed) with a bumped up compression ratio. That thing was a bear to start and would chew up a stock battery like it were cotton candy. The "fix" for many of us was to put in a larger battery from a bigger bike with double the CCAs. It woke the starter motor right up, but required hacking up of the battery mount while adding weight (much more noticeable in an off-road bike). These Shorai batteries are offering even better CCAs than their equivalent lead based counterparts and are unbelievably light. The off-road motorcycle community has tested and approved these things, so car duty should be no big deal.
What is the A/h required for the aux battery and terminal polarity position? I can find a battery that will probably cost the same as one from the dealer while weighing about a pound and a half. The batteries ship with blocks of foam to use as shims because they are much smaller than the equivalent lead-based battery. Looks like a simple bracket could be fabricated by anyone with metal working skills (if we only had someone like that on this board!!) and voila, we could end up with a great alternative to the stock battery that will shed 10 lbs or so in the process (maybe worth .01 seconds in the 1/4 mile). If my battery goes out, I will totally guinea pig this concept.
Unfortunately, their largest battery is only rated at 550 CCAs (yet it only weighs 4.95lbs!). They're still a young company so hopefully they will branch out into the car battery business and we can swap to a better battery that will let us lose another 30lbs or so. I emailed their Japanese contact last year before they began selling batteries and they were open to communication. Maybe I can ask them if they plan on branching out into the bigger battery business (BBB!).
Sorry about the novel in this really old thread, but... get over it
Anyone have any thoughts on this idea?
Old 11-15-2011, 10:37 AM
  #91
GRAFH's Avatar
2005 E55 AMG
Sorry I meant Optima, Optima does not make a plug and play aux battery for the amg.
Old 11-27-2011, 04:08 PM
  #92
GRAFH's Avatar
2005 E55 AMG
Here is the one I found at batteries plus. $65 with coupon. http://www.batteriesplus.com/product...TAX14--BS.aspx Direct replacement.
Old 12-18-2011, 10:42 AM
  #93
saffrontiger's Avatar
W211 2005 CDI, X166 2013 350 BT, 997.1 2008 C4S
Wanted to post my experience. Was getting the 'Convenience features...." error message on start up for a few a weeks. Batteries were over 7 years old. Called MB roadside who came to my home. Checked both batteries and were found to be bad. Replaced in 10 minutes for $160 aux battery and $188 main battery. No other charges for coming out. Saved time and money.
Old 12-18-2011, 05:10 PM
  #94
GRAFH's Avatar
2005 E55 AMG
Dam, you got raped by the dealer via roadside.
Old 12-18-2011, 05:17 PM
  #95
norway500hp's Avatar
mercedes sl55 amg 03'
thats messed up! i had a simular Experience with mercedes here in north palm bch.
its so anoying that they do that all the time!
Old 12-18-2011, 05:38 PM
  #96
GregMB's Avatar
I swapped out the front battery myself this afternoon. Pretty simple DIY.
Does anyone know if the "Visit Workshop" red screen is supposed to go out immediately, or will it shut off by itself after I drive the car around for a while?
I'll be logging about 400 miles tomorrow, so there should be plenty of time for the car to figure out that there's a fresh battery up front.
-G
Old 08-25-2012, 01:57 PM
  #97
boschk's Avatar
2006 CLS500 - Iridium Silver w/ AMG Sportline
Just got off the phone with the service manager ... Gave him the whole blah blah .. $460 for a battery is ridiculous .. blah blah ..want my business in the future blah blah ...
so, after some b^tching, he offered me the cost of an synthetic oil change ($129) for future credit towards any service.
I agreed .. i know i prob should have asked for more .. but, I suck.
He was really pushing the diagnostic crap on me about how they have to run test and check all the codes .. I know its all BS ...sigh..
I got the red "take to stealer" message last night.
Bought a $30 multi-meter and tested both batteries and the alternator in 15 minutes.
It's 5 minutes to reinstall the trunk trim to get to the battery and now that the trim & cabin airbox are already out to check the auxiliary battery, its now 3 minutes to install the new battery and about the same to install the trim.
So, 30 minutes, soup to nutz. The dealer should have charged you at most 1 hour labor + the battery. That's rape for sure.
Old 08-26-2012, 09:34 AM
  #98
novae500's Avatar
W211
If you can't change a battery then. Deserve to get raped by dealer. Most places like adv auto oreiily pep boys will change battery for you free when purchased.
Old 08-26-2012, 11:59 AM
  #99
moosejaw's Avatar
none
Holy Marty Macfly...
A thread bumped from 2008
You didnt catch this?
Old 08-26-2012, 12:28 PM
  #100
boschk's Avatar
So what. It's still a relevant topic of discussion. The last time I checked, people are still getting red battery lights for the first time. In fact, I'm going to do a video on the repair, so other aren't duped into getting gang raped at the dealer by what I see if a cleaverly crafted marketing error message, designed to scare drivers into the dealer.
So, if you don't like my reply, don't read it. You have that power, yes? Viva la thead cops! Maybe I should have started a whole new thread on the topic instead of searching and replying to an existing one. I'm sure you'd have beeched about that too.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: Raped at Dealer!! - For New Battery
