Phenolic spacer install difficutly?
I'm considering buying a set of the Evosport phenolic spacers and was wondering how difficult the install is. Looks like you basically remove the bolts retaining the air plenums, sandwich the spacers between the gaskets, and reinstall the bolts. Am I missing anything, or is it that easy? If so. sure seems like a DIY project.
Do you need longer bolts when doing this?
I will plan to take some before and after measurements of IAT. No doubt the spacers should help reduce the IATs, but getting a larger heat exchanger is also necessary to improve the supercharger efficiency.
