Videos: modified M5 vs modified SL55
I'm not sure about running a modded 55 with a stock heat exchanger.
No matter what size of pump you install.. it will not coold down high IAT's any better than stock.
Its the heat exchager... the key.
running more boost and no IAT's relief.. will have power initially but will suffer after a few hard runs.
LET or Code3 should be able to fix that asap...
no excuses.. but we need to start looking not just at boost but keeping the boost cool.
). The results were astonishing to me as well. Here are the videos:http://www.youtube.com/watch?v=nqrjTd_lZEk
http://www.youtube.com/watch?v=dz61fds9acs
http://www.youtube.com/watch?v=bTu4AnUsjYA
I know someone in the DFW area who has an E55 K4 and we've been trying to setup a time to meet and do some comparisons. We hopefully can do this in the next 30 days.
I have great respect for all the AMG line and still love the cars. Saw a beautiful CLS63 today at lunch and it just looked stunning!
Regards,
Darren
how much HP does the tune and pullys give your M? you beat that 55 pretty easy.
That's ok, we'll be doing more 'testing' I'm sure.
I have some questions:
1) What speeds were the rolling starts from?
2) What gear was the M5 in and what gear was the SL55 in during the rolling starts?
3) To What speeds did you guys race to?
4) Which company did the ECU tuning on the M5?
2. I was in 1st
3. I didn't even look
4.
I launch poorly, Darren is simply the better driver in that regard. I didn't stand a chance from a dig.
Sorry for the semi-hijack, but the vids do look clearer.
wow, you are right... nice find I have some questions:
2. 1st if I remember correctly
3. roughly 100
4. Active Autowerke
cheers,
Darren
?P.S. Even heavier than the Bugatti Veyron w/ AWD and 16.4L W16 quad-turbo engine! What the hell did AMG put in that thing to make it weigh so much? Can't be the convertible top... SLK55 with same 5.5L V8 only weighs 3,300lbs
search the IAT's that Code3 did on the heat exchager... you'll see that the system needs a few minutes to cool down after a hard run over 100.
if you do back to back runs .. basically you were running super hot air into your engine and ECU steps in.
As others have noted, the key is to keep your IAT's under 140 which is a very good level.. no where near ECU's threshold.
While Code3 or even LET are probably able for you to keep you IAT's under 140.. any run over 100 will create heat that both systems will spike.. but the recovery times are seconds not minutes.
Specially in Houston during the Summer.. I would not drive any stock or modded 55 with a stock Heat exchanger.. your car would be good for a few runs and it will need time to recover.
I'm not saying the HE will add power.. but you would of stayed consistent with your runs.
I'm not surprised of the outcome.. but I'm surprised at the way he was pulling at lower speeds.
What do you think the outcome would be IF the SL had headers too? Well until heat soak played a card again....
