warranty expries next month...
a few
what should i have them double and tripple check? anything i should ask them to replace? the car just had the 50,000 mile service done.
thnx
thnx
Have them check the supercharger clutch so that you might be able to get it replaced under warranty.
Also have them take a look at the IC pump. That may need to be replaced too.
2004 E55 AMG, 2002 Porsche 996 TT, 2004 BMW x5 4.8is, 2004 F360
My warranty expires next month too. I had the super charger clutch changed under warranty. I didn't bother with the IC pump b/c I plan on installing the Johnson CM30P7-1 Pump. They replaced the fuel filter module b/c of a recall. Have them check your car if should get new cats. They also replaced the battery under warranty. Hope that helps.
