Summer heat around the corner.
Been thinking about summer coming up, I own a 04-e55 stock engine except for 10-degree fan change. I make alot trips from Riverside to Palm Desert where it can get 115+ degrees. Last year when I would pull into the garage out their the car would be throwing off some serious heat and the fenders were real hot to the touch. My question is do I need to invest in another HE say Let HE or Code3 or is the OEM HE sufficient? I have never had a problem with the car shutting down from heat or high temp. I am going to get a Johnson o30 pump. Thank You
