Fuse location - parking lights
E55 then E63, now back to an E55
Hate the parking lights in high beam housing so removed the bulbs! As expected, now I have 2 messages in display, both bulbs. Looked in manual but couldn't find a fuse chart, thought the fuses were on driver inside dash (covered when door closed) but couldnt pop off cover very easily so stopped. Where are most fuses located? Thanks!
a quarter mile at a time
There are no fuses for the lights, instead, they are controlled by the computer to throw a bulb out warning. You will either need to replace the bulbs or substitute a resistor to mimick the bulb being there.
