Nitrous intercooler sprayer?
Old Apr 8, 2008 | 10:35 PM
hamann69's Avatar
E55 AMG
Is it possible to put one of those on the E55?
Old Apr 8, 2008 | 11:43 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Already looked at it. It won't give you the same results as the ones shown on their website. Our intercooler is actually under the blower and the heat exchanger is in the front of the car. You could spray the heat exchanger for some reduction in IAT's I am sure. How much is anyones guess.
Let us know if you decide to try it out.
There actually might be enough room under the intercooler to mount the spraybar unit but I would be too scared to remove the blower to install and try it.
Plus super freezing parts like that I hear is a big no no.
Old Apr 9, 2008 | 12:08 AM
hamann69's Avatar
E55 AMG
Ya i figured if it hasnt been done already theres probably a reason why. I dont think im gonna mess with it. Im already getting a larger heat exchanger so ill see how that goes.
Old Apr 9, 2008 | 12:35 AM
phatmitzu's Avatar
2005 E55
If you want even more cooling, get a chiller tank in the trunk and run your HE coolant to and back from it.
Old Apr 9, 2008 | 12:37 AM
hamann69's Avatar
E55 AMG
I have never heard of that. Has anyone done this?
Old Apr 9, 2008 | 12:40 AM
BenzoBoi's Avatar
Super Moderator
W221
Is this what you are talkin bout???
http://youtube.com/watch?v=tbD-pY67zoc
http://youtube.com/watch?v=lSaarWNrpaY
Old Apr 9, 2008 | 12:42 AM
hamann69's Avatar
E55 AMG
Originally Posted by BenzoBoi
Yes.
Old Apr 9, 2008 | 12:54 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
couple people have tried it... it's a track only mod and worth 1 run at a time. too much trouble imho but results in a good tenth and 1mph through the 1/4mile. i guess when comparing to the price of other hp mods to our cars it's not too bad.
not a good idea right in front of the intake tubes. if sucked in, co2 will kill power and n2o, while adding power, will lean you out. iirc, frank tried to cool the heat exchanger via a similar method with little to no effect in iat's (but it's been so long i may be wrong).
Old Apr 9, 2008 | 10:05 AM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
I don't know if this works or not, but I guess it makes sense. I see a lot of the kids with turbo imports at the strip with those lawn and garden pump up fertilizer tanks filled with ice water, some of them even use water and dry ice. They just pump them up and spray a cold mist on their intercoolers. Most of them are front mounted or top mounted intercoolers so it is pretty easy, not sure where the coolers are on a 55. Drawbacks I have noticed is that it can leave some water on the pavement causing problems for other people if they drive through it if they are not careful. They all swear by it for track day events.
Old Apr 9, 2008 | 11:38 AM
blackbenzz's Avatar
haters crazy
I have sprayed nitrous on my heat exchanger but have yet to test results.
BTW- if you do get a little nitrous in the intake it will not lean you out. It will be picked up by the MAF and will be compensated with fuel. Its like a dry shot. You will get a little more power as a bonus lol. I only planne don spraying the HE before a pass, not during.
The people that spray their intercoolers with a water/alcohol mix usually have front mount intercoolers and it does work. Also they usually air to air intercoolers, not like our air to water so its a different ballgame
Old Apr 9, 2008 | 11:47 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Water / Alcohol Injection System
Anyone try the alcohol injection system? WOrk very well for other force induction systems.
http://www.activeautowerke.com/viewp...x?id=Product58
Old Apr 9, 2008 | 06:18 PM
chiromikey's Avatar
Originally Posted by blackbenzz
...BTW- if you do get a little nitrous in the intake it will not lean you out. It will be picked up by the MAF and will be compensated with fuel. Its like a dry shot. You will get a little more power as a bonus lol. I only planne don spraying the HE before a pass, not during.
you might be confusing your 55k motor with ours...we don't have maf's.
Old Apr 9, 2008 | 09:30 PM
blackbenzz's Avatar
haters crazy
Oops
Old Apr 9, 2008 | 11:12 PM
chiromikey's Avatar
Oops
lol
