Viabration coming from engine
BTW I would re dyno after a tank of fuel so that the ECU has time to adapt.
Your second dyno should not be considered accurate. The IAT had to be just shy of blower shut down.
It should run true if it looks blurry or you see belt dust or any strange wear pattern on the belt take it into the installer. Make a point to ask how they (mechanics) held the crank, while torquing the bolt, the easy part is holding to 147 Ft. Lbs the 90 degrees is more than "hard to hold" and few shops have the correct tool.
Depends what you mean by vibration though ... does not sound like a pulley at low speed high gear - could it be tranny?
I would find out how they installed the pulley ... in particular how they held the crank still while torquing the crank bolt.
Is the S/C belt tensioner OK - belt not slipping etc and put on right?
after that... its purrs like a kitten.
At a stop.. the engine vibration is so small and the engine sound is almost feels the cars off.
I'm thinking its normal having a bit of hick ups during cold starts.
But not during driving or during a stop light
I have those issues with my C32... at a stop the car vibrates and feels like a slight misfire on the engine.
I have stock wires and changed plugs like 2 years ago. I'm not sure if they gapped the plugs correctly or if my ignition coils are faulty.
I recently did a trans fluid change and the vibration was reduced.
Next I plan to do a fuel filter change and see if the motor mounts are still good.
can you take a video of the vibration you are experiencing?
