Johnson CM30 Question...
2005 Mercedes G55 AMG
Is it hard to install? I wanted to do it myself. Anybody has instructions? How long does it take? Any input will be appreciated!
Thanks in advance!
Thanks in advance!
2015 S212
The 30 is easy to install, but make sure you are ready for a replacment. i am not a fan of teh 30, except that it has more run hours in it than the Bosch one. Flow rates are very similar.
The Bosch one I have is bad, I don't know why, but after 4 bursts, my supercharger is off And I have a stock pulley... So I was thinking of upgrading to CM30... The G55 I drove has the Bosch pump, and somehow it never fails, no matter how I abuse it.
2015 S212
Sounds like it is your pump. My Bosch has never failed me, but MB changed models and programming code to help spare it.
In your case, I'd go ahead and get the CM30. I assume you are out of warranty? If not, get the bosch again.
2003 E55 & 2014 GL550
Did some searching for ya....found a basic install prodecure.
Doesn't look too awful hard.
It is located on the front of the passenger side ofthe car right next to the radiator....
It is very easy to access. Put the car up on ramps or even jack it up and secure it. there is a large black plastic piece that covers the bottom front of the car. You will need to remove the screws holding this up(you can leave the ones on the driver side on as it will drop enough for you to get to the pump.)
Once it is down, you will see the pump, it is the size of a soda can(bigger than your CM30) and has two hoses and one small wiring harness. the hoses will bolt directly up to the CM30, to install the wires, just crimp or cut the stock and attach the red to red and brown to black on the CM30. If you have any other questions feel free to PM me and I gladly will walk you through the install.
ALSO......HERE IS BRIAN S's install of the CM30. He also added the exchanger which you need very soon. For now, very good that you are adding more cooling power. Just use Brians post for pics!!! His install cuts hoses etc for heat exchanger. You are just basically plug and play.
CM 30 install.
Promise, not being smart a-$$ when I say this. Search feature works killer on this site as many of these question have been asked and answered dozens of times. Just some handy info for ya for future stuff. As always though, we're here if you need us. Good luck with the install.
CM 30 install.
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
The Johnson is pretty easy to install and I believe somewhere in the archives someone posted a step by step with pics.
I put one on my '06' because I thought I was experiencing an intermitent failure with the Bosch. Evidently I wasn't because I noticed no difference in the way my car ran with the Johnson.
When I took my car to the dealer for some minor service, they discovered the Johnson pump and threatened to cancel my warranty. Needless to say, I have since removed the Johnson and put the Bosch back in.
Jangy: I still have my warranty, so after reading the last response by speedpeddler and his warranty incident, I might just get the dealer to install another Bosch....
Jackpro, thanks a lot for all that info Seems to be pretty easy. I know I should have used the search button, thought about it after I already posted this thread Thanks again!
Speedpeddler, I can't believe that they threatened to cancel your warranty
On the other note, you did felt NO difference at all in Bosch vs Johnson?
Again, thanks for all your help guys!
You honestly should not feel a difference guys, all the Johnson is going to do is bring those IAT's down faster than stock pump. Only thing that should happen is reduced supercharger shutoff. Still will happen on warmer day until you get the extra exchanger and separate the systems, then it will only give you grief after hard hard use.
If buy "no difference" you meant after a few stomps, the pumps was shut off again, than different story.
PLUS, even when the car feels sluggish, I always check if I can hear the S/C working, and it is...
2015 S212
Absolutely, bro. Take it in. Don't mod what can be warrantied UNTIL it is repaired, just to prove that the phases are tight. In your case, be sure to know how to re-create the effect and explain that well. You may need to demonstrate it for them if they can not reproduce it. But, after it is hit they will likely replace the pump. If the issue continues, they will replace the SC clutch to the "newer" version.
EDIT: I just read that they replaced the supercharger pulley and not the crank pulley, in any case I want smoothness too.
2015 S212
I can definitely reproduce it, I called them this morning and scheduled a test drive with my mechanic next week, so he will see what I'm talking about. Last time, they said they replaced the pump, however they were unable to reproduce anything during their test drive. Maybe If I annoy they enough they will swap my pulley with the 07 SL55 pulley like they did for W211 Beast, lol
1 Post
AMG E55, Stage 1, Strait Pipe from Primary Cats
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
PLATINUM SPONSOR
After taking a part a few CM30`s and understanding the potential restrictions of our systems and pumps; I would stay away from the cm30.. This is just my opinion.. I would use the newer heavy duty bosch pumps (about 30 bucks less).. They bolt right up and do a better job flowing under load per the specs. The Cm30 still has to be rigged to fit in the same stock brackets (lot smaller dia.) and the bosch does not.. The inlet side of the Cm30 is about 40% blocked by a bearing support bracket and creates a flow disadvantage verses other pumps..
If you plan to go with all the bolt ons and larger HE style system, you may want to go with a larger pump , so you have room to grow.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Exoticmetal55
What is the model number for the bosch pump and where can I get it from. I am going to use your knowledge and get the bosch heavy duty pump instead of the cm30
PLATINUM SPONSOR
I bought mine here but Ebay and other places may save you 15 bucks.. Just make sure the model number is the same.. This pump has been great for me..
http://www.siliconeintakes.com/produ...oducts_id=1001
