Faulty oil sensor, visit work shop
Old May 7, 2008 | 01:57 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
Exclamation Faulty oil sensor, visit work shop
Hello,
Got this message yesterday and today. Just recently got oil change to the same brand i have used since i got the car (mobile 1 w40) about two weeks ago.
Oil was completely drained out from the bottom of the car & a special Daimler approved cleaner oil chemical was used, similar to the idea of the ones used for fuel by MB itself, to get rid of deposits and gunk build up.
What do you think could be the cause?
Is the sensor faulty?
Or is it something else?
Codes are
P2007-008 B28 (pressure sensor) : signal implausible
P2040-008 B40 (oil sensor( oil level, temperature and quality)) signal implausible ( oil quality) line mixed up (p1999)
P2039-008 B40 (oil sensor( oil level, temperature and quality)) signal implausible ( oil level) line mixed up (p1999)
and yes did an oil check and it says its ok
Old May 7, 2008 | 06:57 PM
Vadim @ FD's Avatar
S600TT, R350
It appears that oil sensor got damaged by the cleaning process.
Old May 8, 2008 | 02:54 AM
Zod's Avatar
Zod
Thanks vadim
Old Nov 27, 2025 | 01:24 AM
Mercedes s55's Avatar
Originally Posted by Zod
Thanks vadim
did you ever figure out the issue ?
