Johnson Pump tech question
Old May 21, 2008 | 08:04 PM
Icandr55's Avatar
2003 e55
I have an 03 with K2 and Kleeman "uprgrade pump" which is a Johnson pump. I started getting malfunction notice with the Battery. Dealership said at first just auxillary battery was bad and replaced it. 2 days later same malfunction. Now dealer says the new pump is hooked up to some relay that is making the relay fail and keeps draining the aux battery. $600 for the relay and they say if I don't go back to stock hook up it will keep happening. Any ideas where to hook the pump up so it will run continously while the car is on and bypass this problem? Thanks in advance....
Old May 21, 2008 | 08:20 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Call Cory at Klee and tell him what is happening. Just the coolest friggin guy. Have paper ready, he can whip stuff by you pretty fast as he deals with it everyday so it's back of his hand.
KLEEMANN Inc. USA
3455 Fillmore Ridge Heights
Colorado Springs
CO 80907
Tel.: +1 719 473 6441
Old May 21, 2008 | 11:33 PM
Icandr55's Avatar
2003 e55
Thx, great idea. Since it was installed by a kleeman dealer I hope this works out....
Old May 22, 2008 | 02:08 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
in my testing, there's no reason to wire the pump to a continuous power source. with exception to when in cold start mode, the ecu already runs the pump all the time.
...so my advice would be to wire it back to stock. you'll make mb happy and still get all the benefits of the johnson pump.
Old May 22, 2008 | 09:15 AM
Icandr55's Avatar
2003 e55
thx Chiro. I know very little about this and I am taking it to a non-dealer (former) mb tech who owns his own shop. Should the Johnson be a "plug and play" type hook up to the stock wiring?
Old May 22, 2008 | 01:56 PM
chiromikey's Avatar
Originally Posted by Icandr55
...Should the Johnson be a "plug and play" type hook up to the stock wiring?
i know i'm going against the rest of the forum but knowing what i know...yes, there's absolutely no need to change the wiring.
Old May 22, 2008 | 02:33 PM
rflow306's Avatar
2005 E 55
I agree with Chiro if you have the cm30, but if you have the cm90 a dedicated power wire is a wise move imho and use the factory power wire as the trigger on your new relay. I had a three position switch, always on , ecu controlled and off.
Old May 22, 2008 | 05:06 PM
sang55's Avatar
K3 05 E55 sold, 09 GL550
there is no way your bettery drain out because of the direct wire of the pump . I had cm90 pump direct wire with no problem at all in 2 yrs .
Old May 22, 2008 | 05:17 PM
chiromikey's Avatar
i could understand that if the amp draw on the cm90 exceeds the stock wiring, but i wouldn't go out of my way simply to wire it to run continuously.
i actually have mine wired the same way, with a switch in the cabin and i never use it except at the track when the car is off and i just want to pass coolant through the i/c circuit.
Old May 22, 2008 | 06:37 PM
rflow306's Avatar
2005 E 55
I think for the guys like us in the warmer climates the pump pretty much stays on all the time with the ecu.
Old May 22, 2008 | 07:11 PM
Icandr55's Avatar
2003 e55
Okay, thanks for all the ideas. I got off work and investigated a little myself. First of all, I can't believe I paid for the dealer to change the aux battery. It looks like a 20 min job! I found the Kleeman installer ran the red power wire off the pump and hooked it up before the ?relay and then grabbed the red wire coming off this that was running toward the fuse box/ecu and diverted it directly to the aux battery. It is running continoulsy when i turn the ignition on but without starting the engine.
My thought is to get the new aux battery myself and install it and have a mechanic run the power red to another continous source not involved with the aux battery.....if that doesn't work I just hook the red wire back to the oem setup....we'll see.
Old May 22, 2008 | 07:36 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Be sure and check your charging system. You should be getting about 14 volts at the battery terminals.
Old May 22, 2008 | 07:54 PM
chiromikey's Avatar
just realized that you wired this to your aux battery. that's a no-no and any draw above what the sbc system uses will more times than not, cause a malfunction light. either hardwire it to the main battery or back to oem.
Old May 22, 2008 | 08:43 PM
rflow306's Avatar
2005 E 55
There is a 12v supply source in the fuse box that has the ecu, drivers side engine compartment, from the rear battery. You also have a 12v ignition source there but you can use the factory power wire as your trigger.
