Engine Oil level!Visit workshop.
Had an oil change done at MB dealer 5k miles ago.
Thanks.
Longer term, it's worthwhile to invest in the MB factory dipstick tool, which will give you a precise meausrement of the oil level. Using the factory chart, you can determine exactly how much oil to add based on the dipstick reading. IIRC, if the dipstick reads from 167mm to 170mm, the oil level is exactly where it should be. Anything below the 167mm mark on the dipstick means the engine oil is below the specified amount.
Some of these babies do like to eat oil too. Think my tech told me there is a memo around his shop that Benz said a (to him) surprising amount of oil burning every few thousand was "acceptable" to AMG.
What a trip.
If the sensor is whacked, then it could either tell you the oil level is fine (when it isn't), or as in the case of the OP here, it could tell you to add oil when in fact it isn't needed (and overfilling can harm the engine).
I'd say before getting off on a tangent about a possibly faulty sensor, though, checking the actual oil level with a dipstick tool seems like a reasonable place to start the diagnosis. Anyways, that's what I'd do first.
