MKB Tuners FINALLY in the US
2003 E55 & 2014 GL550
Formally announced today.
Only thing I am interested in is this "spring mod" that we have heard about for years and years. Some type of mod to the springs on the the air recirculating system. I would call it EGS valves but then I would get jumped on.
Otherwise from everything I read over the years, basically another over priced tuner.
Here is the price list for modding the C63.
For your AMG we have our complete package which contains the ECU upgrade, exhaust manifolds, and downpipes with cats. The cost plus shipping is $22,091
http://www.theautochannel.com/news/2...12/089806.html
http://www.mkb-power-na.com/
Interesting...I got this quote for the E63's:
The Stage Two Kit include ECU upgrade (a true reflash), headers and downpipes. The complete kit excluding shipping is $18,832.15.
As you may be aware with just this upgrade we went over 204mph a Nardo.
Hmmmmm
Hmmmmm
I have the Renntech chip alone with a few other minor minor mods and My car was up to 188. Does it really matter that extra little bit more...I think I spent about 1/4 that much I wish them luck with those sales....
MKB IS RELIABLE
MKB is the only tuner that does not change to bigger pulleys to gain HP. My CLS 55 AMG installed the full MKB package, and the goes like a rocket. It did a 0-200km/h in less then 12secs, how about that.
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
I'm glad your car went 124mph in less than 12sec...with 4 posts you shouldn't be so sensitive.
Many will even argue that the smaller supercharger pulley will slip more and be less efficient.
Not saying your car doesn't make lots of power, but MKB has to swap out the pulley to make that kinda power.
Full MKB package
Increase in performance 456 kW (620 HP) at 5800 rpm, 800 Nm at 4190 rpm
modification:
high performance camshafts, exhaust headers s/s,
special compressor clutch, bigger throttle with optimized air intake tube,
adaption of ECU incl. V-max delimiter,
Limited slip differential 45%
reinforcement transmission incl. adaptation TCU,
shorter transmission ratio ( I = 2,82 ) for a better acceleration rate
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
I think its got something to do with getting more/less clean air to the 02 sensors and in this way adjusting the ECU to utilise this in some way by making the car run leaner / richer - I've given up asking Wett. for an explanation all they say is "it gives more air!" in a very heavy german accent.
Did not know MKB used them too - would be interesting to see a picture of their units.
Do they do SLR style coolers?
Yes that must be the UGLIEST I have seen yet....They really riced that out...
yeah the MKB puts a lot of power out, but with what i spent on this car I am happy to use one of the other tuners around like Renntech and VRP which I have aready done business with because they are much more economical to my budget modding
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Yeah its the same thing Wetterauer put on my car ... who knows wtf the germans have worked out here ... but I still recall the flaming I went through for bringing it up when I had it installed!
MKB can hold boost
True and not true. MKB switches the supercharger pulley/clutch to a smaller milled version to essentially do the same thing as a larger crank pulley.
Full MKB package
modification:
Full MKB package
modification:
Did I misread? I didn't think anyone really questioned (yet) the performance issue or even reliability. I think the main response was the performance for the money spent and the comparable performance by other tuners for a lot less.
