Replacing resonators with an X-pipe.
2015 S212
Too true. That custom exhaust is the way I am going, but I am so torn between X pipe and straight pipes. Why put in an X pipe unless i need to tune in some backpressure? Help, i am confused on this. Is the minor scavenging really the reason?
S600TT, R350
Ok, let see if we can make sense of this.
1. Does X-pipe make any power vs. straight pipes?
Yes, on a highly tuned engine (i.e. NASCAR, ALMS and so on) where proper header system with proper cam timing, collector tuning, software tuning and on and on and on...... In other words not E55.
In addition, there is an H-pipe ahead of the resonator on a stock E55, so the only thing X-pipe replacement for resonator will do is to change the sound. There is no power gain. I have dynoed cars before and after.
2. Why not e-bay X-pipe?
Two problems, E-bay pipe is not a true X-pipe - the chamber in the middle is too big, it wil not create any scavenging effects.
Secondly, it will not fit 55 or 63s as spacing between the pipes is too wide and will require redoing the whole exhaust to make it fit properly.
3. So what does X-pipe do on 55/63?
Sound. That is it. On 55 it does not realy make dramatic difference due to 9:1 CR. On 63, with 11.3:1 CR it does better, sort of flat crank Ferrari sound. The problem with MBs is that the cars are very well insulated and in order to hear anything inside, car has to be very loud on the outside, which most owners do not want.
Family Sedan w/5.5 K
ahhh...a gift from the gods...clarification!
2015 S212
old daily driver '07 E63(gone); new dd '14 750xi; 2013 Viper GTS
That is one fine lookin' header system. Craftsmanship also looks top notch. Nice goin'
does anybody have a sound clip of a CL63 that comes endowed with an X-pipe instead of Resonator
.. just to understand if sounds better than a C/E 63 that has not the X
#32
i removed the resonator with a 2.5"
straight pipe on my e55 and i was so dissappointed , it absolutely has noo sound different from stock.......i also did the same with my s55 and the sound was amazing.....a nice growl , sounds very muscular LOL , i dont know why , i guess the exhaust design are different????
