Headlight adjustment
Old Jun 20, 2008 | 06:31 PM
dkallencat1's Avatar
After having my car lowered all the way around I noticed at night my headlights are pointing down to much. Is there an easy way to adjust them up a little? I don't really want to take it in to the dealer for this. Thanks
Old Jun 21, 2008 | 04:13 AM
Rafal's Avatar
2017 S63 Coupe Iridium Silver
Quite easy. on each side there are three hex 7mm allen key socket screws visible on top of the light cluster: one for the high beam and two for the bi-xenon: side to side and up/down adjustment.
Point the car 20'/6m away from a wall, turn on low beam, insert the allen key in each hole and turn either way watching what happens on the wall in front of you. It takes about 2-3 x360deg turns to notice any movement and then it gets quite dramatic.
Don't raise your xenon low beam too high or your shutter-controlled high beam will shine the lights onto the trees and into truckers eyes!
AFTER ADJUSTING THE BI-XENONS, PUT ON THE HIGH BEAM AND MATCH THE HIGH BEAM LIGHTS TO YOUR HIGH BEAM BI-XENONS' ELEVATION.
Good luck.
