Cracked Python tube.
Old Jul 8, 2008 | 09:39 AM
E55BKS's Avatar
A slow Tahoe!
Has anyone else had there Python tubes crack? Mine cracked along the seam on the side that meets up with the air inlets by the radiator. I thought carbon fiber was stronger than plastic. My installer noticed when he installed the 80m TB a few weeks ago.
Vic is checking with manufacture to see if they'll replace it.
Old Jul 8, 2008 | 09:57 AM
blackbenzz's Avatar
haters crazy
Supposed to be stronger but not a sflexible depending on how many layers it is. Good luck with getting it replaced
Old Jul 8, 2008 | 10:17 AM
vrus's Avatar
2003 E55 AMG
Brian,
This is the first one that has been reported to crack.
I sent an email to the manufacturer last night once I got off the phone with Curt and they replied this morning and said they will replace it for you.
Let me know if its a driver's side or passenger side. I'll get one and have it shipped out to you.
Old Jul 8, 2008 | 10:25 AM
E55BKS's Avatar
A slow Tahoe!
Thanks Vic ......that's great news, this is the one on the passenger side of the car.
Originally Posted by vrus
Brian,
Old Jul 8, 2008 | 11:38 AM
Andy0331's Avatar
'08 CL63
I know at least one of mine has cracked as well, although the crack was still pretty "short"; maybe 1/2" to 1" tops. Same location, underside, along the seam on the intake/radiator side. I'll pull them both tonight & check 'em again to see if it's grown & if there is a crack on the other side.
Old Jul 8, 2008 | 08:28 PM
Andy0331's Avatar
'08 CL63
I pulled mine, passenger side is fine, but the drivers side does have a crack about 1.5" long on the bottom, intake/radiator side.
I thought it was smaller (as posted above) but didn't measure it before, so I'm not sure if it's growing, or the same. There's also some evidence of "delamination"/clouding/yellowing of the clear coat around the crack, but I assume that's from the crack, not the cause of it.
I'll have to borrow a decent camera (or get a new power supply for mine) to get a good pic; my cell phone pic sucks bad enough that you can barely make out the carbon fiber, let alone a crack.
Old Jul 8, 2008 | 10:51 PM
Rock's Avatar
Administrator
Drives Slowly
Don't quote me on this but I'm thinking that a crack in an intake tube will allow you to flow even greater amounts of air into the TB.
Greater airflow = more HP.......... and more HP means a faster car..........right?
No cracks in mine but if someone can show me increased trap speeds with cracked tubes............... I have a hammer standing by.
Old Jul 8, 2008 | 11:01 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
That sucks, I had a hole in a condom once!
Old Jul 9, 2008 | 12:51 PM
phatmitzu's Avatar
2005 E55
Werd.
I'm going to check on mine when I get home.
Old Jul 9, 2008 | 01:18 PM
bfnnrgn's Avatar
SL65
Originally Posted by phatmitzu
Werd.
Your condoms?
Old Jul 9, 2008 | 01:48 PM
bobgodd's Avatar
2004 E55
Originally Posted by bfnnrgn
Your condoms?
Check 'em twice!
Old Jul 9, 2008 | 02:39 PM
phatmitzu's Avatar
2005 E55
Your condoms?
Yeah. Im going to blow air into them...
Oh, and I'll check on the Python Tubes too.
Old Jul 11, 2008 | 08:19 AM
E55BKS's Avatar
A slow Tahoe!
Delivery date?
Do you have an approximate delivery date? PM me if you need my address.
Brian,
Old Jul 11, 2008 | 09:16 AM
That's one way to make it look bigger!
Old Jul 12, 2008 | 01:23 AM
jangy's Avatar
2015 S212
Damn, mine are cracked all the way down!! Send me some new ones!!
HAHAH!!! I have none!!
Old Jul 13, 2008 | 03:46 AM
Andy0331's Avatar
'08 CL63
Either I suck or my camera does, but it's hard to get up close focus. Here's a picture of the crack area; the most obvious thing is the delamination area spreading from the crack. Other than the delamination, the crack in mine doesn't appear to be as severe as the OP's; mine's running around 1.25" long & not "gaping", but it does go through to the other side.
I'm not sure where the OP took his picture, but he managed a lot less glare than I did.
