Benz Drag Race Showdown MIR 11/22/08 Discuss!
What's the weather like this time of the year? We're used to 70-80 degrees in November in Atlanta. I'm considering driving up and am shopping around for a co-driver. I might talk my dad into it - he used to wrench and test drive for his cousins '62 Corvette (super gas, I think) and would probably love to make a pass or two.
Depending on $$$, I may get a tune before then.
I'm asking about mid-November.EDIT: This is what I'm getting at. 44 degrees average is a bit chilly to stand around in the parking lot shooting the **** all day.
http://www.accuweather.com/us/md/mar...ric=0&month=11
JAYCL600
jrcart
ChicagoX
Stephen04
TMC M5
blackbenzz
juicee63
Andy@MHP
Anyone else?
Post if you'd be up for a little competition.....first annual "Mercedes Benz North America Shootout"........Remember, the faster car doesn't always win. There will be traction issues and reaction times to consider.
And i'm in - money sent.
Ahh Tuning Tech - a little less posting and little more wrenching whaddya say big guy?
JAYCL600
jrcart
ChicagoX
Stephen04
TMC M5
blackbenzz
juicee63
Andy@MHP
RARFINANCIAL
ALWAYS LOOK OUT FOR THE QUIET ONE
I thought we would have more Cali members onboard
IS THE NO ON E ELSE
Tom
And for all you guys that wanted to race a C6 Z06 heads up and think you're faster, Jamie Furman will be in attendance
1) Blackbenzz/Ahmad - CLK55 Kleemann MD
2) JayCl600/Jason - CL600 MD
3) MHP/Andy - C63 and JGC SRT8 OH?
5) jmf003/John - SL55 VRP MI
6) Stephen04E55/Stephen - Da Beast S600 (reigning champ) VA
7) MachC5/James - CLK63 Black Series NY
8) Rarfinancial/Rick - Renntech CLS63 CA
9) Dasrok8/George - C6TT IL
10) Mthis/Hagi - C63 NY
11) 05Venom/Chris - E63 NY
12) jrcart/Jim - Evosport CLK63 BS IL
13) Chicagox/Wayne - LET E55 IL
14) JT55/JT - CLK63 BS NY
My best 60's on each of those tires:
MT - Haven't tried yet and will be on 16's so it isnt a fair comparison
BFG - 1.66
R888 - consistent low 1.7x
RA1 - also consistent low 1.7x
What size wheel are these going on? 18's I'm assuming. If you decide that you want to go with R888's and want to save a little money I have a pair of 275's that I put about 250 miles on and had to take them off because they were rubbing. I also have a pair of lightweight discontinued Koseis (~18lbs) with 245/40/18 BFG d/rs I need to sell as well (Cut 1.67 60' on these). You could switch the tires out for something wider like a MT ET Street Radial 265/40/18. That was my original plan but decided to order 16's
I have 4 - 18 inch Kosei's with 9 inch rims which should support 265 or 275s. I might be interested in your R888s. So you think MT's over BFGs.
Do you have a link to the MTs? What tire pressure do you go with 18-22lbs? thanks.
Here is a link to the tires http://www.mickeythompsontires.com/s...ETStreetRadial
As for tire pressure, I got this off their website:
Inflation Pressures
On the racetrack DO NOT use starting pressures below 11 psi.
Recommend pressures for:
P295 and larger sizes: 11-14 psi
P275 and smaller sizes: 12-16 psi
On the highway we recommend running 75% of the max psi as notes on the sidewall of the tire.
Burnouts
The tread compound used in the ET Street Radials is designed to heat quickly and does not require a heavy burnout. Continue the burnout at a level RPM until the engine starts to pull down. We do not recommend a dry hop after the burnout.
Bead/Wheel Slippage
Some bead/wheel slippage (1/2” or less) may result during the course of a 1/4 mile (or 1/8 mile) drag race. This is normal. Check for tire slippage when you check your tire pressure after each pass.
Excessive Rim Slip
If continued or excessive (more than ½” to 1”per run) wheel/slip is experienced, Mickey Thompson recommends the use of “Beadlock” wheels for ET Street Radials. Bead screws are not recommended and could lead to tire failure and or damage.
I run the Corsas at 21 pounds and the MT's everywhere from 15-19 PSI, like I said still learning and experimenting. I'm running out of time so I better figure then out soon.
The weight is in kg so roughly ~6lbs
Just an idea. Wonder if there are any locals that could possibly bring down a nice jack or 2 and a torque wrench. Gotta feeling there will be a lot of tire swapping going on between brothers.
I bet JR will have it covered but just in case.
I see two tires on this link and the top ones look like DRs that you would be referring to but don't have the 18 inch.
Will the bottom ones hook 1.6x's also? The tread looks very different. thanks.
