Supercharger cut out / loss of power .
1. I/c pump (secondary water pump)
2. Divert valve stuck (diverts water/coolent away from the supercharger)
3. Air locks in the coolent (badly serviced)
4. ECU malfunction
5. Incorrect coolent
6. Supercharger dead (self explaintary)
I went to Mercedes (who I supply non Mercedes car parts too) and they imidiately told me is WAS the i/c pump (without inspection). I had it changed (not by merc) and no more problems. I am sure alot of people know this but I just wanted to make it clear for anyone with this problem, its more likely to be the pump than anything else.
Want to solve the problem real quick?
(1) Isolate the cooling circuit.
(2) Add an extra pump to increase flow.
(3) Add a secondary radiator to the ic circuit.
The heat soak and s/c shut down problem will go away.
Plenty of companies around offering this solution if you don't want to get your hands dirty...
Do you know if there is a setup where I could install the Code Three Performance Heat Exchanger and keep it seperate from the rest of the cooling system in the car?
Thanks,
Josh
Never mind, I found it.
https://mbworld.org/forums/w211-amg/...nger-prep.html
