FS: Quaife Differential
Old 08-22-2008 | 05:40 PM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
Any takers for a new in the box Quaife LSD for an E55 at $1300?
The part number is 48 309 185 and should fit all years of E55 and if memory serves the SL55 and many other applications.
I also have available an "installation kit" for an '03 E55 at $155, this will not work on the '04 or later due to bearing differences. The kit consists of a complete set of ring gear bolts, a pair of new bearings with races, a pair of output flange seals, and an axle nut which are all new parts from MB. This is everything you should need short of gear oil and a tube of black silicon gsket sealer to do the installation.
I will sell the diff alone but would love to find someone with an '03 to off the entire package.
Please PM me with any questions.
Old 08-22-2008 | 05:51 PM
BenzoBoi's Avatar
Super Moderator
W221
DAYAM IT...I would be all over this...but I don't got the cash to front..
AND
to top it off...I have an 03 too...AHHHHH
Old 08-22-2008 | 07:31 PM
AND
Sorry that doesn't work out as it would have been a pretty much perfect for you.
Old 08-22-2008 | 07:58 PM
BenzoBoi's Avatar
Super Moderator
W221
All good buddy!!!
It would have definitely come in handy with all the stuff happenin to the car now...but oh well...
GL again on the sale...
BUMP
Old 08-22-2008 | 10:39 PM
OXOJE55's Avatar
///AMG
will it work with a 05 E55
Old 08-23-2008 | 02:29 AM
Andy0331's Avatar
'08 CL63
The actual part number for the 03 + E55's is QDF9V; it should be on the side of the diff. The number above is a stock or SKU# that Autotech (US Quaife dealer) uses to list it. I had to call, thinking I got the wrong part since 48.309.185 is nowhere to be seen on the diff itself.
So, yes, the diff listed above will fit an '05. Just letting you know the real deal so you don't freak like I initially did when mine arrived.
Hope this helps & good luck with the sale!
Old 08-23-2008 | 02:38 AM
jangy's Avatar
2015 S212
What else is needed with an '06 E55?
Old 08-23-2008 | 08:20 AM
It will work on an '05 or an '06 just fine. The only difference is that the bearings in the install kit that I put together would not be correct as they changed from a matched pair of bearings to a pair that are different thicknesses. The other bits I have (output flange seals, axle nut, and ring gear bolts) should all work. So what you would need is my install parts without the bearings, a pair of bearings from the dealer for $130, and a tube of black permatex, MB or Loctite sealant and you are good to go.
Andy is correct, I provided the stock number not the diff number....my bad!
Old 08-23-2008 | 10:18 AM
cls55's Avatar
do we need to tune the ecu after the install.
Old 08-23-2008 | 10:39 AM
No, you do not have to change a thing.
What you notice after installing one of these little gems is that your traction control light doesn't flash like mad as the power is going were it belongs....to both rear wheels!
Old 08-23-2008 | 03:43 PM
BENZGal's Avatar
From: school west coast-Summer Internships Va and Bmore
E55 (for sale if the right offer comes along)...too many others to list
For those of you that like to corner these beasts this is a must.
Jangy,
This was made for you!
Old 08-23-2008 | 06:22 PM
cls55's Avatar
if it fits cls55, and no other parts are needed im game.will you ship it to miami?
Old 08-23-2008 | 06:39 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
These are quality lsd's.
My tech has installed 2 and not a single shim was needed. Direct bolt in and play. Awesome unit.
Only thing that beats it is the messiah AMG lsd but who wants to spend that kinda cashola.
Old 08-23-2008 | 07:20 PM
if it fits cls55
Sorry, no idea if the CLS55 diff is the same.
Old 08-24-2008 | 06:41 AM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
sorry, what is the messiah AMG ?
Old 08-24-2008 | 08:28 AM
AMG has an LSD that is avaialble in Europe from the factory but it is some big bucks. I would tend to argue that the Quaife diff is actually stronger.
Old 08-24-2008 | 08:58 AM
dyno's Avatar
if that messiah is the same tha's inside SL63 cage diff
... then, I should receive it tomorrow
Old 08-24-2008 | 10:29 AM
cls55's Avatar
lsd
dyno,can you buy it from the parts department?is it 30 or 40% locking.
Old 08-24-2008 | 10:32 AM
jjtoma's Avatar
07' CLK63 designo Graphite/Black; 07' E350 Sport White/Cashmere
Jakpro1: Do you remember the labor charge for the Quaife diff installation. Thanks
Old 08-24-2008 | 11:56 AM
dyno's Avatar
understand what you mean: 40 was the performance option for 63, while 30% was the option offered for 55.
Don't know if there's a p.n.
I was not interested in it ..because I just bought the Quaife.
I simply had to buy the complete differential cage because I was looking for the pinion&crown that sits inside of it.
in any case, if SL63 has a LSD as stock, I'll get it included.
it should be a 40 but I'm not sure.
Old 08-25-2008 | 07:51 AM
I am pretty sure that the upgraded AMG unit must be installed by AMG and is not availale over a parts counter unless they have changed things.
Old 08-25-2008 | 09:45 AM
cls55's Avatar
lsd
blacksport,i emailed quife im still waiting for a reply.
Old 08-26-2008 | 09:15 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
Quaife LSD is by far better than any of the OEM clutch / clamping style LSD's manufacturers use and charge an arm and a leg for - its rediculous. The OEM benz version is no different.
Besides, Quaife is not only 0-100% lockable, but also lifetime guaranteed....
Dayam, still got to get round to fitting mine!!!!
Old 08-27-2008 | 07:35 PM
Sale pending to Johan!
Old 08-28-2008 | 01:17 PM
mercixus's Avatar
E55
Transfer is on way
Quick Reply: FS: Quaife Differential
