Common E55 Problems? How to check?
Old Sep 4, 2008 | 09:34 PM
ECBAOBAO's Avatar
nascar
Hello,
I searched the forums and saw alot of mix reviews for this car. I would like to know some things:
I researched that some common E55 problems are
- supercharger chirp? [this is the pullies?]
- intercooler pump
- alignment
- acceleration jerk
- heatsoaking
- weird blowing sound out of muffler
- maf problem
- ecu shuts off supercharger after hardpulls or sitting in traffic (when does it turn it back on?)
How do I check for these problems?
Exactly how common are these problems? Some people say their 03s never had a problem ever, while some people in 03s or even 05s have tons of problems. How reliable are these cars?
Old Sep 5, 2008 | 08:11 AM
OzE55's Avatar
2003 E55
see responses in your other thread.
serious problems are uncommon.
Old Sep 5, 2008 | 08:33 AM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
The supercharger chirp is normal as is a slight jerk on engagement. I have had 3 blown AMG's and this adds to the experience and is no way a problem. There is a newer clutch design from '07 and on that reduces this by softening engagement.
The intercooler pumps do fail but are an easy upgrade to a better one at $130. Search for Johnson CM030.
The alignment on all Benzes can get involved and can require the addition of adjustment bolts which can get pricy. The solution is to find a good indy shop.
Never had a heat soak issue burt I am not a drag racer. I do however live in heat.
Never heard of an issue with odd sounds from mufflers.
The E55 does not have a MAF.
The supercharger shutdown is due to temp and will turn back on when the temp returns to normal. This has been an issue when it gets really hot and you are stoplight racing or under heavy extended loads. The "fix" is to upgrade the heat exchanger. With my pump and heat exchanger, I have NEVER had my SC shutdown.
I have not heard of any year specific issues and in most areas, these cars are rock solid with only the usually little issues that one would expect from a car this complex.
- intercooler pump
- alignment
- acceleration jerk
- heatsoaking
- maf problem
Old Sep 5, 2008 | 11:07 AM
ECBAOBAO's Avatar
nascar
thanks alot guys, i really appreciate your replies
do you think I can show you the carfax stuff that was done to it and if it looks normal?
thanks!
Old Sep 5, 2008 | 01:57 PM
thanks!
I don't know that is such a thing as "normal" but post it up!
Old Feb 22, 2011 | 10:27 AM
SilverE55AMG's Avatar
E55 Amg W211
Johnson CM030
I've read all of the info here and still didn't find anything that could help me with my issues. I'm currently getting a P0410 Code, secondary air injection pump and also another code for the temperature below thermostat temperature. If anyone knows where I can start I would really appreciate it. I've been told to check the SC, but when you turn on the car the belt is spinning and the SC is spinning as well. When reving the engine to go above 2200rpm the belt starts spinning faster then the SC. I was told that its magnet activated, when reving above 2200rpm then the SC kicks in and should start spiining forceably fast. But like I've described thats not whats happening in my case. Does it activate while in Parking gear or only if you are driving. B/c when in P it only goes up to 3800rpm.
Also that temp issue is odd, b/c I've recently replaced the thermostat and getting this code. All suggestions will be appreciated.
Also where is this Johnson CM030 can be purchased. Looked all over the web and didn't find anything.
Old Feb 22, 2011 | 10:40 AM
grantwoodtx's Avatar
GLE 63S
What's up with all these newbies reviving old threads?
Anyway I guess you didn't srearch to hard for Johnson CM30 http://tinyurl.com/4ey3xex
Old Feb 22, 2011 | 11:57 AM
E55 Amg W211
Thanks for the quick response, I've found it at HP Autowerks Inc as well. Hey anything you can tell me on my questions above??????
Old Feb 22, 2011 | 11:58 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Ya search.
Old Feb 22, 2011 | 12:08 PM
E55 Amg W211
emoving ,,, I would of never figured that out without your help brother...
Old Feb 22, 2011 | 12:10 PM
emoving's Avatar
Glad I could help!
Old Feb 22, 2011 | 01:35 PM
E55 Amg W211
Can it be the SC clutch going bad and the IAT???
Old Sep 23, 2015 | 05:49 AM
new211e55owner's Avatar
mercedes benz w211 e55
have a problem new to this site
just got my 03 w211 e55 recently when im driving normal or anything when its gonna shift from 2sd gear to 3rd the rpm shoots up and car slows down any ideas to what it can be i toke it to machanice but all he said was u need a new trany so before i do that i wanted to see if anyone had ever had this problem if so plz help
Old Sep 23, 2015 | 07:41 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Do you realize you are replying to very old threads? Your mechanic may be right, but search "conductor plate" first.
Old Sep 23, 2015 | 04:53 PM
well that cuz i cant figure out how to put up a new tread bro
Old Sep 24, 2015 | 08:02 AM
Left hand side of your screen right above all the threads is a white rectangle with the words "new thread" in it.
