Steering Wheel Shift Buttons - Programmable via STAR?
Anyhow, my stock steering wheel did not have the buttons on the back for shifting...
The AMG steering wheel does, and the wheel had a small wire inside of it with this connector:
After I removed my original steering wheel, I noticed that the plastic doohikie on the steering column had a port that accepts the connection from the AMG steering wheel:
Nothing was plugged in there originally because the stock steering wheel did not have shift buttons.
I plugged the connector from the AMG wheel in the port but the car has no reaction to the buttons... I tried pressing them in D and when already in M mode but nothing changes when you press the buttons.
Does this functionality need to be enabled via STAR or is there more to it than that?
If indeed I am able to "activate" this functionality on my car, I would love to pick up a set of VRP Paddle Shifters...
http://vrptuning.com/cart/index.php?...products_id=14
Those are SICK!
Check this thread out, it might be of some help. When you take out the airbag support bracket, there are two pairs of wires running from the steering column, to where the shift buttons would be, one pair on the left (down shift) and one on the right (up shift), and I believe the colors were red and blue for one pair and red and black for the other pair.
In this pic, the wires are connected in the "top" spot of the connectors just to the right of the steering wheel mounting bolt, hope this helps some lol.
