Dyno methods ?
Old Sep 5, 2008 | 08:14 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Dyno methods ?
What are the proper ways to dyno these cars on a dynojet? Tried to get some baseline runs in today but had trouble with proper gear and kickdown.. tires also spun on the dyno on all runs.. I had the car in dyno mode.
Speed limit shut down showed 142 mph on the runs. Car was run through 3-4 th during sampling gears.
First run TQ light was not working and only showed hp. STD was the sampling.
Would like to go back but need to have the dyno/car set for how everyone is running..
Opps, also on the 3rd try a heater hose blew off at top speed .. fluid everywhere.. hose was next to brake booster.
Saw a 2008 C6 zo6 with rear twin exhaust turbos on it there.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 6, 2008 | 01:03 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
PM sent.
Old Sep 7, 2008 | 12:11 AM
gonzjed's Avatar
germans
Originally Posted by ChicagoX
PM sent.
CHIX...if its not too private, can I get some info? I plan on strapping down to get some pre mod #'s.
Old Sep 8, 2008 | 07:14 PM
PLATINUM SPONSOR
2003 CL55
Sounds like we need a TYDOHTD55 (Tell your dyno operator how to dyno a 55) thread...
I bet a lot of people need to know how to inform shops on dyno mode, cooling, keeping tranny from down shifting, reading RPM, strapping a Benz correctly to the rollers, etc. etc.
I think we are god for 1-3 single gear pulls only.. no time to mess around or your IAT`s will cook and power gone..
Blowing my heater hose off was a mess!! 3rd pull of 2-4th gear WOT runs!!
