STAR Help
Old Sep 6, 2008 | 12:41 PM
JosephLINY-E55's Avatar
2005 E55 AMG
STAR Help
Can any board members explain in detail how to do the follwing STAR Modifications:
1. Process for Lowering the Cooling Fan Activation 10 degrees lower as many have done on this board. Actual step by step process as I need to pass this info onto my MB Tech.
2. Process to Eliminate the stupid Keyless Go Chime
3. Process to Lower the car slightly as I am only looking for approximately 1/2 - 3/4 inch drop. Would welcome opinions as too what works or should I bite the bullet and just get a used Renntech/Brabus/Kleemann/etc used LM???
4. Process to Eliminate Seat Belt Chime
Any help very much appreciated and thank you in advance for your time and considerations. Kindest personal regards, Joseph
Old Sep 6, 2008 | 05:45 PM
jangy's Avatar
2015 S212
Bro, it won't happen. That is a competitive edge that nobody will give up right now. Even many MB Techs that use STAR on a routine basis don't get trained on the many mods that we like, so when someone learns to do it in a timely manner they keep it to sell.
Hopefully, that will change soon as more and more enthusiasts are getting access to STAR or alternatives.
Old Sep 6, 2008 | 08:34 PM
Timeless's Avatar
2005 E55 ///AMG
+1...plus it is a pain in the *** to go into that much detail.
Old Sep 6, 2008 | 11:17 PM
hbr's Avatar
hbr
'05 E55 on ADV1s
OT sorry............
What would the fan temp reduction run at a dealer or shop?
Old Sep 6, 2008 | 11:42 PM
gonzjed's Avatar
germans
that's just crazy...but it does make sense from MB's point of view.
Old Sep 7, 2008 | 02:44 AM
jangy's Avatar
2015 S212
Actually, it may end up being On Topic. I don't think we'll get too many DIY posts in this one unless it is the members getting involved and learning.
That mod (and most fun ones) are not available on a typical menu at your friendly neighbor MB service department so you will need to find someone willing to do it on the side or that has a STAR in his own shop. They are starting to pop up in SoCal. Heyvon Motors has an MB master tech with a new star setup. the works. VRP also has access to the star. If you want to hit up the dealership, ask your SA (you never know) or try the mobile techs, they get a mobile star to travel with. You could always get lucky and get that mod cheap.
Cost on STAR mods is variable, but around $300 to get in. Once connected, etc. you can do a load of mods quickly, IF the tech knows what they are doing. It is 100% labor, so you are looking at their time.
Old Sep 7, 2008 | 09:35 AM
2005 E55 AMG
Thanks for the Info
Jangy thank you for the reply, I have a MB Tech to do it but he is a rookie and does not want to try to change anything... I personally thought it would be a 5 -6 step programming change and obviously no big deal, but as usual I must be wrong... Best regards, Joseph
Old Sep 7, 2008 | 09:50 AM
shardul01's Avatar
2003 W211 E55
i was told that lowering via the STAR system takes 2.5 hrs of labor, dont know if that is true
Old Sep 7, 2008 | 10:48 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
+1, Star lowing is very complex.
I will get you instructions on the the cooling fan mod. Tech can do that in secs.
Chime for Keyless and Seatbelt I will check out on my Star.
Old Sep 7, 2008 | 10:57 AM
2005 E55 AMG
Obviously lowering the car is a big undertaking and very complex, but the three other mods seem like rather simple procedures ( my assumption but you know what they say about *** sume... ) Turning off chimes and telling the fan to start at a lower temperature point?
Old Sep 7, 2008 | 11:04 AM
2005 E55 AMG
Thanks Jakpro1!!!
Dear Jakpro1: Thank you for sharing your knowledge, your time and consideration!!! Very much appreciated... My E55 runs so dam hot and stays hot even after short drives I thought the water pump wasn't running... Thanks again, Joseph
Old Sep 7, 2008 | 11:09 AM
2005 E55 AMG
Jangy and Jakpro1 any other simple STAR Mods?
Guys you are a wealth of knowledge and it is very much appreciated by me and I am sure other individuals on the forum!!! Any other simple mods via Star that you have found to be positive - Sorry for all the questions but I am like a child asking begging for knowledge... Kindest regards, Joseph
Old Sep 7, 2008 | 08:20 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Who ever told you that has NO Clue on that matter...
Unless he take the car in..goes on break
Gets back from Break..goes to lunch
Then after lunch yet another break..Then lowers the car via the star
Old Sep 7, 2008 | 08:28 PM
jangy's Avatar
2015 S212
Mark is right about the time involved in lowering. Like I said before, it is all about the time it takes. I've watched it be done in 20 minutes and I've watched taking all day just to get it perfect. Once you have done a particular model, you learn what it likes and how much to play.
Other mods: I hate that the headrest moves when I move my car so I like it off. I also like to turn off the side marker lights so I don't have to fake the computer or put carpet over the bulbs. The chimes, but it will turn off all the chimes.
Old Sep 7, 2008 | 09:47 PM
hbr's Avatar
hbr
'05 E55 on ADV1s
Thanks bunches
Old Sep 12, 2008 | 07:43 PM
2005 E55 AMG
Any instructions on "simple" mods - like fan temperature drop? Remove chimes etc
Old Sep 23, 2008 | 11:47 AM
OXOJE55's Avatar
///AMG
Any update on the info to do the fan mod
Old Sep 23, 2008 | 12:46 PM
Jakpro1's Avatar
Okay, here is the step by step for ya
In Star have the tech go to Main Groups then click Control Unit Groups the click Drive, then click ME SFI Motor Electronics, then Control Unit Adaptations, then Correction Programming, then Electric Suction For Engine or Air Cond.
The screen will look like below.
***Very important. You want to INCREASE the value up to it's max by clicking F5 until screen says "reached it's maximum". This will allow the fan to come on sooner. If you decrease the value on the screen, the fan will come on later in temp.
All done.
Old Sep 23, 2008 | 03:50 PM
2005 E55 AMG
Thank you!!!
Jakpro1 "Thank you very much", it is greatly appreciated!!! I like the idea of my fan kicking in a lower temperature!!! I do not see any downsides to that simple modification... Especially since you can fry eggs on these motors even after a short drive... Kindest personal regards, Joseph
Now if I can get those damn chimes to be silenced I will be a happy Keyless go driver... I dont mind the Seat belt chime as I always drive with it on, but the chimes on the Keyless go drives me crazy...
Old Sep 23, 2008 | 05:05 PM
Oxygen's Avatar
W220 S65 AMG
JosephLINY-E55, I live down the road from you... care to share some STAR love with my car and me?
Old Sep 23, 2008 | 05:39 PM
2005 E55 AMG
Hey no problem Smithtown... I live in the Smithtown Pines area... I am hoping to borrow the STAR unit from a friend. Once I get all the programming instructions I will ask to borrow the unit and I will help anyone who wants the same mods... I do not plan to attempt the lowering unless someone really can send me all the details and pitfalls. I have been chasing used Renntech LMs but really want the version 2 not version 1.
Old Sep 23, 2008 | 05:42 PM
2005 E55 AMG
Nice ride Oxygen!!! Do you ever go to the Thurs eve meets at Best Buy in Garden City Carle Place in Nassua Cty??? I am planning on going just to introduce myself...
Old Sep 23, 2008 | 06:02 PM
Oxygen's Avatar
W220 S65 AMG
Thanks!
Yes I've been there every Thursday since this summer started...
PM me your # let's meet up I want to check out the ride.
