MIR RENTAL Oct. 13th aka Columbus day
Old 10-14-2008 | 05:24 PM
  #76
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Stephen:
Thanks again for all your help!!! Good luck getting your beautiful ride back in fighting condition for next month's event!
Tom
Old 10-14-2008 | 05:37 PM
  #77
Rostam's Avatar
97 420
That was fun...
Thanks Ahmad, that was a fun day. Can't wait till next time. I need to break into the 14's.
My best times were 15.0 and 10.4.
Old 10-14-2008 | 05:49 PM
  #78
juicee63's Avatar
2007 CLS63 030
Originally Posted by Mathmik
I'm Headed up. an 20min....see you guys there. Looks like I'm the Only CLS63 so far. DON'T Forget your Helmets fellas!!
Whaddja run bro??
Did you eclipse the stock CLS 63 record???
Old 10-14-2008 | 06:00 PM
  #79
JAYCL600's Avatar
new balance
Originally Posted by juicee63
Whaddja run bro??
he didnt run
Old 10-14-2008 | 06:18 PM
  #80
BlackOnBlackCLK's Avatar
2001 clk55 AMG
Originally Posted by Stephen04E55
My passenger side axle broke this time out which is normal for me. If I had been running well I wouldn't have cared as much. This axle broke after a slight tire shake at approx 60' where the traction compound wasn't as thick and the track was slicker. I said all day that it felt like the track had a banana peel after the 60'. All it took was a slight bang and that was it. Now the entire rear is new and both axles will have been replaced. Whoopee! My best run of the day was 11.54@120 and N20 didn't help at all as the car hit every torque limit on shifts. When the car hits these torque limits or it detects slippage it completely shuts down for about a second or so. Arrgh...it is very irritating when it happens. If you have thoughts of changing the transmission fluid...please have a very good reason to do so as my transmission has shifted horribly ever since. It is bad enough now I need to shop around for a new 722.6.
Stephen if you are looking for a good trans call eddie at southern hotrod (888)big-hemi he did my trans and I love it. It shifts awesome and it will handle crazy power.
I took blackbenzz for a ride Saturday he can tell you what he thought about it.
Old 10-14-2008 | 06:21 PM
  #81
blackbenzz's Avatar
haters crazy
BIG +1 on that. After riding in Curts car I was ready to pull the trigger but then the diff blew on my car yesterday so thats where the money is going
Old 10-14-2008 | 06:44 PM
  #82
Mathmik's Avatar
14-F Sport, 07-CLS63 2003-HUMMER 2004-Suburban 2008-MAX 2005-YZF R1
Whaddja run bro??
I didn't run man!... There wasn't any car out there fast enough for the CLS63 WE OWN THE TRACK!!!
Ok thats a joke guys!!
Old 10-15-2008 | 02:21 AM
  #83
juicee63's Avatar
2007 CLS63 030
what the heck...
Dam , seriously why did you go and not go out a mop up some other forum dwellers?
Old 10-15-2008 | 07:45 AM
  #84
BuilderBill's Avatar
1997 SL500
Thank You for the Kudos!
We are having GREAT success with the High Torque Capacity NAG1's in the Chrysler Hemi's that are pushing upwards of 1,000 hp and torque (turbos, superchargers and massive spray).
The stock paper clutches just won't hold the additional power that some of you are putting in. We redesigned the problematic clutch packs with Kevlar clutches to take the massive abuse and modified other problem areas to the point where MB would not recognize these units. Eddie and I used 6 different high performance testers before we even released the units to the general Chrysler crowd.
Obviously, we wanted to have all the bugs worked out before we even thought about releasing the High Torque Capacity NAG1 to this crowd.
Thanks again for the kind words, as site sponsors, we will advertise these units more in the future.
Bill
Old 10-15-2008 | 07:49 AM
  #85
1997 SL500
Is that the same diff that is under some of the Chrysler vehicles?
Bill
Old 10-15-2008 | 09:41 AM
  #86
blackbenzz's Avatar
haters crazy
Bill
I have no idea. I had a kleemann LSD in it. Probably gonna pull the diff and take a look inside tonight.
Do you guys offer just a valve body modification? I already have a torque converter done. I am having a problem on my 2-3 shift (bounces off the rev limiter several times before shifting) and I think the valve body may help, do you?
Old 10-15-2008 | 09:44 AM
  #87
1997 SL500
I have no idea. I had a kleemann LSD in it. probbaly gonna pull the diff and take a look inside tonight.
Just looking at saving you some $$$.
There are units available on the Chrysler LX site.
Let me know if you need help.
Bill
Old 10-15-2008 | 11:23 AM
  #88
blackbenzz's Avatar
haters crazy
Bill
You have a pm thanks
Old 10-15-2008 | 11:44 AM
  #89
1997 SL500
Thanks for the PM...diagram was helpful.
Mercedes ring gear diameter 210mm(Chrysler non-SRT) or 215mm(Chrysler SRT)?
Let me know specifically what is broken...gears, spiders, LSD, axle etc.
The valve body mods actually work in conjunction with the new Kevlar clutches in the High Torque Capacity NAG1.
Could Andy help you out with reprogramming the TCM to bump the line pressure / shift pressure and shift rpm?
Please don't tell me that your 2-3 shifts are taking longer that they used to....that means a new NAG1.
Bill
Old 10-15-2008 | 12:17 PM
  #90
Benz-O-Rama's Avatar
Had a great time, guys. I was a "all show, no go" participant as my car sat in the corner as I drank beer with my wife in the stands.
Weather couldn't have been better for spectating.
Can't wait till November.
Old 10-15-2008 | 02:40 PM
  #91
JAYCL600's Avatar
new balance
youre such a lush
Old 10-15-2008 | 02:46 PM
  #92
TMC M5's Avatar
Originally Posted by JAYCL600
youre such a lush
For those keeping score at home:
JAYCL600 = The Pot
Benz-O-Rama = The Kettle
Lush = Black
Old 10-16-2008 | 11:57 AM
  #93
Fikse's Avatar
STS,FGT,12C,P85D,M4
there was a A6 running high 11's?
http://www.dragtimes.com/Audi-A6-Timeslip-16642.html
Old 10-16-2008 | 11:59 AM
  #94
blackbenzz's Avatar
haters crazy
Yes, it was a stage 3 2.7T engine
Old 10-16-2008 | 01:13 PM
  #95
That thing was no joke. I thought it was the beer getting to me when I saw him run for the first time.
Sick. And looks bone stock, accept for the AMG rep wheels.
Quick Reply: MIR RENTAL Oct. 13th aka Columbus day
