SBC[H] starts working after brake pad replacement
So, I've had the car for approximately 15K miles (had 40k on it when I bought it) and after this brake pad replacemnt job all of a sudden this new cool feature is alive! Thanks to the wonderful people on this board, I found out this is not a problem but a cool feature of the car to HOLD the car in place at stop lights.
What is confusing is why it did not work before the brake job and now it does.
Anyway, I guess it is working as designed and now I have to make sure to disengage the SBC HOLD before turning the car off.
On a side note, the EBC red pads work well other than some screeching at very light pressures coming to a slow stop...but I hope it goes away after some brake in (no pun intended).
Comments?
My bro just put on the EBC red stuff on his SRT and is very pleased with them. As good, if not better, stopping power compared to the brembo pads but significantly less brake dust. I'm sure you'll notice the same results. I plan on going with the EBC red stuff when it comes time to change my pads as well.
I would be yelling at my car. "Yes thank you, I know its in park, thats why I put it there and turned the car off"
how do you get the car to hold at stoplights??
If I come to a stop and depress the brake hard enough, the SBC[H] appears in the display area (speedo area). This HOLDs my car in place without having to have the brake pedal depressed. I guess a feature designed for real stop and go traffic.
If this SBC[H] is engaged and you put the car in park and hit the off button to turn the car off it tells you in big red freakout lettering that the car is in park. You then have to depress the brake to get it out of this SBC[H] mode.
So basically you cannot turn the car off while in this SBC hold mode.
Hope that makes more sense.
It was annoying until I figured out what this was...so now I just make sure it is not in this mode when I turn the car off.
