Bad Johnson pump?
The 80mm TB sure feels strong , added on top of the pulley
My ATAP had to be reflashed from an online update glitch and was gone for 3 weeks. I dynoed two weeks ago and ATAP was gone, so I did not know what the IAT`s were on the dyno.. I think they went very high, as heater line blew off and power drops were crazy..I see the pump is rated for 212F and I guess we could have fried the pump on the dyno? No way to tell.. I will double test power to the pump before jumping to a lot of conclusions..
I knew I should have babysat the dyno operator but was on a phone call. I heard him blast WOT through at least 2-4th gear twice.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Glad I had ATAP. Without it, I would wonder ever time the car felt a little slow if the pump was out.
I'm having some abnormal IAT and at this point, I'm blaming my Johnson pump.
Exotic,
How did you test the power to going to pump?
I wonder if I can try and get mine cover under warranty as I have only had it installed for about 2 months.
Without SDS just unplug the connector and use a power probe to the positive on the pump and see if it turns on.
