Lowering module problem! Can anyone help?
if it isnt much then you shouldnt worry. The airmatic system constantly adjust depending on surface, wieght etc.
post some pics and we will get a better idea,
Just mess with it and 3 in the front is too high, set it down a notch at least.
The shop is used to installing these modules. I took it back to the shop and they couldn't find out the problem either. Seems like the passenger rear is off about 1/8 of an inch. They called Renntech and they said it must be a weight distribution problem. They said to raise the diagonal wheel one level higher. That doesn"t sound right to me either.
You suggest doing a calibration using the on-star? What is the step in doing that while the car is lowered. Do I need to turn the module off before? Thanks for the help.
https://mbworld.org/forums/w211-amg/257269-renntech-lowering-module-install-w-remote-diy-ers.html
I would definitely try a slight raise to the diagonally opposite corner before you let some other tech fumble with the factory height settings. The ability to do good adjustments using SDS seems to be more of an art than a science.
