Transmission Oil Change...!????
When is it wise to change out the transmission oil? My car has 78K miles on it. The Indy shop recommends to have it done soon. Any opinions or comments are greatly appreciated.
Thanks,
Mike
Thanks,
Mike
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
Did my sister's C32 at 60k and it was very dirty almost looked like the color of engine oil. Flushed the fluid and changed the filter. At 78k you should do it, the next owner will thank you, haha....
dont intend to thread jack but hey abhatti, i change my engine oil all the time, for somereason I feel intimidated by doing the tranny oil, is it pretty hard on our cars or is there anything special to doing this or is it pretty much the same just different spot and fluids?
Is no different than any other tranny you've done. Easier in fact in that the pan gasket is U shaped and wraps around the pan lip, guaranteeing a good seal and it has a drain plug. Pan bolts (very long) bottom out on plastic clips which hold the pan in place. 8nm torque for most pans. Fill level is important. Need the factory tool dip stick OR to confirm there were no prior leaks and to measure EXACTLY how much fluid came out so you can replace with like amount of SAME temp fluid.
I would say this is certainly a job someone that can change their own oil is capable of doing.
