TPMS sensor question
As If the sensors are in fact installed they should show up
The dealer tech was actually surprised that nothing was needed other than to reset through the on-board function.
And when I had the set taken off in spring and the stock wheels/tires reinstalled at a wheel/tire specialist, I again didn't encounter any problems.
The only difference here is that I removed my stock wheels and put on the aftermarkets without sensors originally. After a long ride the car detected that there were no sensors installed and displayed that in the dash. A few weeks later I bought sensors for the aftermarket wheels, but now the car won't go through any type of detection phase, it will just read no sensors installed right off the bat when I turn on the car.
When I removed the stock wheels it took a really long ride for the car to detect that the sensors weren't there, but now it doesnt even bother checking and just displays no sensors installed.
I find them more trouble than they are worth, I am in tune with my vehicles where I can feel if I am 8-10 pounds low in a tire. They are very annoying, especially this time of year living in a climate that has daily temps ranging from low to mid 40's at night to upper 70's - low 80's during the day. In the morning the sensors are on due to the cold air, but in the afternoon they go away when the air warms up...quite an annoyance.
edit: TPMS was not standard on the '06. i think it was only offered with specific configurations.
In the OP's case, the car should pick the sensors up, even if you did not reset. The reset just makes it happen faster and also "calibrates". What size wheels and rims did you go with? I ask because it is hard to get the working sensors into a low profile tire and some of the aftermarket sensors don't jive.
I'm running 20" Maya MRS with the sensors and am using siemans 315mhz sensors which are a direct replacement for OEM
I'd throw the OEM rims back on and reset the ecu, then try to reset the getup. If that stalls, then let warranty deal with an electrical gremlin.
The tires are 305/25/20 and 255/30/20 and the sensors fit in there with an adapter for my "L" shaped valve stems
