Big props to LET Motorsports
We could have made plenty of power, but not with your timing requirements. I thought stock power levels with over 2 degrees less timing than stock was pretty decent.
Your car sounds great, BTW.
Our V12 development was delayed slightly by the move, as we've been swamped with the 6- and 8-cylinder projects.
With that said, I would recommend you attend the event firsthand to see our results. I would prefer the forum members personally witness the before/after dynos themselves rather than a random sheet of potential vaporware.
Gains are in-line with other respected tuners, and sometimes a little bit more.
I have PMed you my number, if you have any further questions. Please let us know how we can help.
What's your take on adding a TB after an initial tune...
Current mods and or mods installed for a Nov 1st tune:
-ASP Pulley
-Thermostate
-K&N Filters
-X-pipe welded in
Afterwards, adding a TB... do you see it necessary to tweak the tune by adding a bit more fuel as the consensus of a TB install would be allowing a little more air intake and hence need a bit more fuel or is the ECU learning curve able to distinguish and eventually add a bit more fuel to cover the difference in air intake?
I believe the TB to be within the dynamic range of the ECU, given that your car will be dyno-tuned. With a less 'precise' tune on your car (eg: mail tune) it might not produce all of the power possible without a tweak. Don't get me wrong - there is plenty of power to be made with our mail-order tunes.
My LT fuel trims after a dyno tune were 1.5% correction or less after 3 months. There is no substitution for a custom tune on our finicky cars, IMO.
01bolt- no problem
Dyno on my car to date is from the previous owner. ASP Pulley and thermostat and it put down 413/501. As you can see from the graph, lots left on the table due to fuel dump from the addition of the pulley with no tune. I would think 20 more to the wheels can be had just by leaning A/F back out to around 11.9 or so and me having installed K&N filters.
That said, I look forward to an LET tune on Nov 1st.
