**ATTN: TUNNERS AND ALL $1000 QUESTION ***
open her up - highly doubt that the ECU cannot be opened without damaging the internals. But aviod force...
The fact that MB pinpointed directly at loose bat cable as root cause of ECU failure makes me believe it is a common problem. I willing to bet that the damage is within ECU.
CLS63
The ESP inop light (triangle) is not what I am talking about . On the disply it spells out " ESP INOPROTIVE READ user MANUAL" in red.
What does the ESP, radiator fan, temp and no start have to do with one another and why does the key not lock or unlock the doors or is not active when car is in no start mode? the key remote is non opp then works with no apparent patterns..
CLS63
GL550, C55, 335i Coupe, vintage Mustang
Thanks for clarifying. That tells me something has corrupted the ME coding. Those symptoms are all things that occur when programming the ME via SDS. Sounds like either the ME has not been SCN coded for the vehicle correctly or there is a corrupt software file.
Nick
Nick
It's only corrupt when warm - correct? WHen everything is cold - car runs fine - right?
#32
CLS63
What is SCN? ( serial #)
You say software file.. then a complete reflash and recoding should fix the problem? How couls this happen? Now we are getting some action.
Oh and when you say ME is that the same as the ECU? Man all these damn codes..
#34
Sorry, technical terms. SDS is the Star Diagnosis System(star machine). SCN coding refers to individualized codes transmitted to the dealer via a secure website for a specific vehicle. Most ME(motor electronics) control units in MB vehicles as of MY 04 require SCN coding to even start the car after loading new software. Basically, we "Flash" the module, then have to code the vehicle information into the ME. The only thing that confuses me is that it happens when the car has been running for 10 minutes. SCN coding is definate, if it's not done, the car will not start. Try keeping a small fan on the module when running the car, and attempt to duplicate the complaint. If it still acts up, I would definately reflash the ME, re SCN code it and see what happens. But I work at a dealer, and I don't have a way to save your tune and reinstall it after I'm done with the programming. My hunch is that the software has a problem where it doesn't communicate properly with the necessary MB code for the antitheft portion of the ME.
Nick
Nick
#35
Nick
#36
CLS63
That makes a lot of sence to me Because it seems as if the key is not programmed at times. I just remembered that when my key is in the same pocket as my cell phone I can not unlock the doors by pulling on the handel also about a month ago I lost all my phone book in the car and can not use car to dial or answer phone. blue tooth still works but no phone functions. Should I have the dealer recode the ECU? I have my tunes save on a laptop.
#37
By tunes, you mean your Engine Management tunes, right? I would have them program the ME, and see what happens. If it still happens, I wouldn't rule out the control unit being fried completely, but that would be a start. If this works, I take Paypal, or, cash on your way east to Maryland.
Nick
For the Bluetooth, disconnect the puck, delete the MBphonesystem from the phone's bluetooth profiles, and re-pair the phone to the car.
Nick
#39
The ME has fuel maps that are different at different coolant temps. What's to say that the temperature input to the ME doesn't affect other things also or that there is a glitch that causes it to affect other sections of the ME.
Nick
Nick
#40
CLS63
Nick
Nick
#42
but at least the doors should open. Maps change while running as well, car would then freak out while running as well which if I understand OP correctly is not the case
#47
CLS63
OK. I have figured it out and the car runs perfect now.
It was the CHROME MUFFLER BEARINGS they were creating to much heat at plus 5g's, a little mothers metal polished and all is well now...
#49
If the problem happens only when hot then pull the ECU when hot and put it in the freezer for 20 minutes or so while keeping the hood shut and everything else warm. Put the ECU back in to see if it now works.
You could also put the ECU in a 150 degree oven for 20 minutes or so an put it in a cold car.
If the problem is the ECU it will show itself with one of these tests.
#50
