Question about hood liner material
Guys, what is the real purpose of the black fiber hood liner material that lines the inside portion of the hood? Is it used as sound deadoning? Is it a thermal barrier to keep engine heat away from paint, is it used to keep heat produced by sunlight beating down on the hood away from the engine? It just looks like like it would insulate the hood and keep excess heat under the hood that might otherwise escape it also looks like it might just add a little extra weight, albeit not much weight, but useless weight none-the-less.
Any help, I think I am going to remove mine, pros vs. cons of doing so?
2015 S212
My Black Series has an aluminum hood. Do you think there are any performance benefits from removing the liner? Obviosly there will be minimal weight savings (4-5 pounds), but do you think it will allow any additional heat to escape possibly resulting in cooler intake temps under there? Aluminum should disapate the heat pretty well I would assume. Just a thought I have been pondering for a while and figured it was at least worth asking.
2015 S212
