80MM throttle body, need wiring help
997TT, R8 V10+, G550, Plaid S
my tb took a crap and i got an 80mm one to replace it from the dealer.
here is what i got
AMG 80mm TB - 113 141 05 25
S/C inlet 80mm - 113 140 09 12
S/C inlet gasket - 113 141 07 80
80mm TB gasket - 137 141 07 80
80mm Y-Pipe with tubes - 113 090 03 29
do i need to change pins in the wiring or is it plug and play?
here is what i got
The "SEARCH" function is your friend; try using it. Took about 15 seconds to find:
https://mbworld.org/forums/showpost....&postcount=247
yeah i did find several thread saying 1-4 and 5-6. i just wasnt sure because there are several part numbers that people have used in the past.
which plug should be used to swap the wires?
The pins do come out. I used a magnifying glass to determine where the tab of the pin was located within connector housing, and then used the pin to depress the tab for removal.
