Jacking area point
Old Nov 10, 2008 | 07:59 PM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
Jacking area point
My jacking area point is weird, it's a hole???
Am I missing a part that goes in the hole?
(my 4 corners are the same)
pix
Old Nov 10, 2008 | 08:22 PM
jerryho's Avatar
bmw
You are missing the "Jack pads,"
The jackpads are rectangular with a thick plastic screw that pops it into the hole on the chassis.
You can get the jackpads from MB for about $10/each. You'll need four of them. =)
Old Nov 10, 2008 | 08:53 PM
hbr's Avatar
hbr
'05 E55 on ADV1s
missing from where? did they come with the car?
Old Nov 10, 2008 | 09:00 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
It's what the dealer uses on the lifts at the service facilities - looks like a small puck that inserts into the hold to keep the car from moving while on the lift. Gives the car more stability on the lift than just the friction fit of it's own weight. Perhaps the jack that came with the car has a built in puck that is the same ??
Old Nov 10, 2008 | 10:49 PM
jerryho's Avatar
bmw
When vehicles are transported, these jack-pads are removed so that the tow-truck drivers can "hook" the chains into the chassis.
Mercedes and BMW uses this procedure, not sure about other makes.
