Problems already on my 09 E63...
Good luck and keep us posted.
you cant throw a car into gear from a roll in reverse...
I am all for if your not happy with the car return it before its too late. Cause if you have less then 1k miles on it and have a list of complaints you should just get out of it now and find something else.
As far as your steering pulling thing goes, make sure you are on a totally flat road before saying its out of wack, cause these cars tend to feel a lot of the road and if your tires are in the wheel groove on the road it might pull one way or the other making you think your alignment is out when its not.. Find a really flat surface and see if it still does it.
I'm sure I will fall back in love with the car once it is fixed. You guys would be pissed too.
It wants a complete stop before it will provide instant response.
that's the way it is.
Have the dealer flush the trany incase anything broke off and floating around in there. If metal shavings get caught because of the flush, at least the trany would likely break while under warranty.
"normal" is relative. The more refined of a car you get the more temperamental it will be. If you want an AMG to drive like a truck, then you may have bought the wrong car. The 63 already has stalling issues at low RPM. By adding the load of reversing and then hitting drive without giving it gas, you are asking the car to either rev to stay alive or shut down. It chooses to shut down because MB does not want to have a surge in a driveway.
If this one can't do this simple task for 100K then it is going back and I want my money back.
