Half my pulley belt is gone!
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
After a night of fun driving I get a check engine light on, which has happened in the past and not been anything serious. Later on i hear some strange noises, for a little while ,but then they went away.
After i got home desided to pop the hood and have a look....
and did i have a look!![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Half my super charge belt got eaten alive by the Beast!
I could see the super charger (teeth
)pulley rings...(will post pics in the morning)
SO my question is this how did this happen?
I recall reading that the ASP pulley ate belts..but i do not have an ASP pulley
and i have a ruf engagment at 2k rpms
Thanks Khalid
![action](https://mbworld.org/forums/images/smilies/action1.gif)
Thanks Khalid
PLATINUM SPONSOR
You need to check your idler pulley`s. Bearings go bad , IDLER pulley`S wobble and kaBOOOOM!
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
