Vibration when I brake-
I am guessing my brakes are warped but don't see how. I figure the 6.3 brakes being two piece and drilled would be pretty hard to warp plus I dont drive hard.
any ideas beside warped brakes
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
http://www.zeckhausen.com/avoiding_brake_judder.htm
1. front control arms
2. front ball joints
both are fairly common, go about 30mph and slowly press the brake if you feel vibration and possibly the steering wheel shakes a bit than those items need to be replaced
The rotors are probably the issue here. If the problems were ball joints, bushings, or wheels, then you'd have the vibration other times too, not just when you are braking. You probably need new rotors.
FWIW, in my experience, the fronts are more likely to warp than the backs, because of the extra bias up front. You might get away with just the fronts.
