Need a little help... pulleys
Old Jan 16, 2009 | 09:09 PM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
As some of you know i'm working on a custom amg supercharger project and i need some help with these pulleys in the image below. So whatever you got, names of them of part numbers. any info will help alot. I need to score these parts to make this project happen. And a thank to ScottCLS55 for the pic.
Old Jan 16, 2009 | 09:57 PM
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Out of the 3 pullies the one in the center is the tensioner pulley. I will check tommorrow to see the left one and let you know what pulley is that
Old Jan 16, 2009 | 09:59 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
So, you’re fitting a supercharger?
Old Jan 16, 2009 | 11:01 PM
hooleyboy's Avatar
C55,SL55,C63
YEs I'm fitting a AMG supercharger to my C55. I've got the supercharger, intercooler, airbox, and crank pulley. now i need the supporting pulleys, belts, H/E and hoses. A custom pulley will be made for the supercharger to lower the boost.
Old Jan 16, 2009 | 11:25 PM
hooleyboy's Avatar
C55,SL55,C63
Now other than the steelership were can i get buy this stuff?
Old Jan 17, 2009 | 10:11 AM
mkonei's Avatar
05 C55
cool project. two questions: how much boost do you plan on running, and are the pistons forged or cast?
Old Jan 17, 2009 | 01:19 PM
amg guy's Avatar
2024 GLE 63 S Coupe 2020 E 63 S
I ran 8lbs boost with my old e430 with cast pistons and 10 to 1 compression with a compressor. I ran that car from 90k to 135k without any problems from the engine. rwhp and rwtq was 341hp and 351 tq. I believe the NA 55 motors still have cast pistons, but they up the compression ratio to 10.5 to 1. The kompressor 55 motors come with 9 to 1 compression and forged pistons.
You will most likely have to pull timing out via an ecu tune and add fuel to run much boost. I'm not sure about this but I think that the amg kompressor in stock form puts out 11psi.
just my two cents.
