MBUSA replaced short block @ 12,000 miles?
Old Jan 20, 2009 | 06:59 PM
damascusE55AMG's Avatar
BMW nut looking to move to an E55
Question MBUSA replaced short block @ 12,000 miles?
Greetings:
I've been following the W211 E55 for about a year now... mostly following this forum and reading older magazine publicatoins, etc. Every once in a while I come across an item that leaves me curious for more information.
I discovered a 2003 E55... at just 12,000 miles the owner took his car to the MB dealer to address a mechanical issue:
- Owner complained of abnormal knocking on cold starts
- Dealer discovered a bearing that was bad on one cylinder - 'spun piston' - 'connector rod problem? the result:
- MBUSA: 'short block replaced' under factory warranty
Has anyone heard of anything similar? I cannot imagine what the repair would cost without a warranty.
Would the value of the E55 be deminished because of the engine repair?
Looking forward to hearing your thoughts...
Old Jan 20, 2009 | 08:14 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Last time I checked, bottom end kit for the 55 was 23,000$ from the stealer. That's just for 8 Pistons and a crank, kit must be sold together. They won't split it up. Maybe it's come down a bit since then, but still gotta be in the teens for sure.
Add in labor and THANK GOD FOR WARRANTY!!!
Old Jan 20, 2009 | 10:18 PM
E55Pilot's Avatar
2004 E55
More likely it spun a bearing and that requires at least a new crank. One very spendy repair
Old Jan 21, 2009 | 09:10 AM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
My BMW M Roadster ate it's motor at 12K miles and I sold it for top $$$$$ about 6K later with a new motor so I wouldn't worry if it was done at the dealer and done correctly.
I would never take a car with a rebuilt engine (at the dealer) but a factory replaced short block or long block wouldn't phase me.
Old Jan 21, 2009 | 10:11 AM
jmf003's Avatar
'03 SL55
Originally Posted by Blacksport350
...a factory replaced short block or long block wouldn't phase me.
+1.
Old Jan 21, 2009 | 12:35 PM
... sounds right...
