For those with iphone's
you might want to look at this.
http://www.devtoaster.com/products/rev/index.html
Rev Features
Built-in Metrics
The iPhone is a powerful computing platform, and Rev takes advantage of all the iPhone's built-in technology to provide interesting metrics about your vehicle. These built-in metrics, available without the aid of additional hardware, include:
Lateral and Forward Acceleration: Graph your cornering, braking and acceleration G-forces. (Also available in Rev Lite)
GPS Track: Visual track displays your location and acceleration data - see how you are braking and accelerating around corners. (Also available in Rev Lite)
OBD Metrics
Rev gives you access to lots of vehicle metrics, communicating via the ElmCanII-WLAN device to extract highly accurate, real-time data directly from your vehicle's ECU. Those metrics include:
Vehicle Speed
RPM
Fuel Consumption
Engine Coolant Temp
Fuel Pressure
Calculated Engine Load
Throttle Position
Intake Manifold Pressure
Air Intake Temp
Timing Advance
Mass Air Flow
Fuel Level
Barometric Pressure
EVAP System Vapor Pressure
Fuel Trim
and it does that wirelessly
I have it and it's pretty cool. The are open to suggestions so maybe we can get more car specific features for our needs
Rev Features
Built-in Metrics
OBD Metrics
Vehicle Speed
RPM
Fuel Consumption
Engine Coolant Temp
Fuel Pressure
Throttle Position
Air Intake Temp
Timing Advance
Mass Air Flow
Fuel Level
Barometric Pressure
Fuel Trim
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Damn I was going to go fishing this afternoon, but now I may need to feed my I-addiction. Looks like a good find E55pilot.
From the website:
The ElmCanII-WLAN: Rev's Hardware Companion
Rev communicates with your vehicle via its physical OBD-II port. Interfacing with this port requires an OBD-II hardware device that supports the 802.11/WiFi interface on the iPhone and iPod touch.
Our device choice is the revolutionary ElmCanII-WLAN from CarCode-Müller. They have been developing great OBD-II hardware since 2001. In addition to providing serial and USB OBD-II hardware, they were the first company to bring Bluetooth OBD-II to the world market, and in November 2007, CarCode-Müller became the first to create a WiFi-based OBD-II device. One year later, DevToaster has worked closely with CarCode-Müller to create the next version of this great device, providing a much smaller new enclosure and engineered with the latest in WiFi and OBD-II technology.
Description
The ElmCanII-WLAN is a wireless interface to your vehicle's own computer, connected and supported by a standard called OBD-II. This device allows Rev to connect to your vehicle through an extremely fast wireless interface.
Features
Check out the great features of the ElmCanII-WLAN:
Small size—easy to tuck anywhere in your vehicle.
Works with Rev right out of the box! Just setup a connection with your iPhone or iPod Touch.
Powered directly from your vehicle. No batteries or cigarette adapters needed.
Easy-to-use web interface for advanced wireless setup.
Create a standard infrastructure or ad-hoc network.
Create an open network, or provide WEP/WPA encryption
Blazing-fast wireless communication over 802.11b (11Mbps) or 802.11g (54Mbps).
WHOA! The device needed to use this software is $229! Plus the $49.99 for the software. I think I'll pass.
http://devtoaster.com/store/index.ph...j77gju168ocn21
