Putting the E55 on Blocks??? Help!
Old Feb 22, 2009 | 07:40 PM
E55 Bulldog's Avatar
2012 C63 Black Series, 2003 Hummer H1 KSC2, 2003 Hummer H1 HMCO, 1997 Hummer H1 HMC4, 1969 Jaguar E
I am going to get my wheels refinished this week and would like some of your opinions on the best way to put my car up on jack stands.
I have 4 jack stands and would like to know the best, safest way to get the car up on all 4 stands without any problems.
I worry about jacking up one corner and placing a jack under the door frame then jacking up the other side and doing the same thing with the weight of the car possibly shifting on the opposite jack stand… and so on and so fourth for all 4 stands.
What is the best Jack point in the center of the car if I wanted to jack up the front end all at one and then the rear end all at once?? Looking under the car I don't know where the best place to put the jack without doing any damage to the car.
What do you think the best way is??
Thanks for any info you can provide.
Old Feb 22, 2009 | 09:45 PM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
I wouldnt put any supports under the door frames, its a heavy car and you want to avoid such concentraited stress on an area that wasnt intended for it.
There is a jack point in the front, I noticed it while changing oil. Look down the center, it sits between the first two large plastic splash guards, but it doesnt stick out so its not obvious. I didnt see one in the rear... sometimes people jack up rwd cars by using the diff but I'm not sure if thats the best way to go with this one. Can you borrow someone's jack and just leave the rear on two jacks while the front is on jack stands?
Old Feb 22, 2009 | 10:13 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Rear can be lifted via the diff
Old Feb 23, 2009 | 09:17 AM
dosnt the rear diff cooler under there block it?
Old Feb 23, 2009 | 09:23 AM
There are places for the supports that run along the frame under the doors, shouldn't I use them to place the jack stands?
Also, as for using 2 jacks, I don't like the idea of having the rear end held up by jacks for any extended period of time. You never know when one could loose pressure and start to drop the car.... my luck I would wake up the next morning, go out into my garage, and see my car sitting on its rotors
Old Feb 23, 2009 | 09:43 AM
mekantor's Avatar
Yeah, you can place stands in the intended locations under the doors, but I was mentioning places where you could lift the car without using them, and then place the stands.
Use a mechanical jack (like the one that comes with the car, or a scissor jack) and it wont go down on its own.
