3 piece wheel air leak
have found a slow leak, about 3 to 4 psi a day on one of my Radenergie r10's from wheelpower. the leak is where the center meets the lip, i think there is a seal around this area. my local tire shop said i should send it back to Wheelpower for a repair and they wouldnt repair it. Anyone know of a wheel shop in the SF bay area to fix this?
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Any good performance shop can reseal it as long as it is not bent. All they have to do is unbolt the barrel remove the old silicon sealer and reseal it with some new silicon.
If it is bent then you should send it back.
wheel repair
although a bunch of jack a$$, wheel techniques knows and will be able to fix the leak, they are down in santa clara
