Help please... Low battery
My instrument cluster says
"Low Battery
Conven. Functions
Turned off
Temporarily"
Or something along those lines.
Anything to worry about? What do I do? Why is it there?
...and YES there is something to worry about! if it's your alternator your car will suck the power out of the main battery and then the sbc battery. after that happens you will have NO BRAKES!!! DO NOT TAKE YOUR CAR ON A LONG DRIVE...i wouldn't even take it out of the driveway!!!
I would get that message if I did not use the car for more than 2 weeks. I found that activating the alarm (by locking the doors) caused it to happen in a week.
Once the car started, and the battery charged as I drove, it went away.
These things are notoriously bad. Warning if you are out of warranty, may wanna do some searching about aftermarket batteries......ones from the stealer could not be more overpriced.
"Low Battery
Conven. Functions
Turned off
Temporarily"
Keep the roadside assistance number handy. As mentioned above, if it is the alternator, you will be stranded after complete failure of your electrcal system. YOU WILL NOT HAVE BRAKES or anything that is electrical.
Hopefully I can go to the dealer on Monday.
It said visit workshop with a pic of the battery only on WOT, and after I brought it home and left it running outside for about 5 min, I came out to beeping and everything red saying, battery/aternator...stop engine
it wouldnt start at all and says the same thing.
I charged the small battery in the front to try and diagnose the problem, and it started! I am getting a new small batt tomm and see if that fixes the problem...
does autozone carry the small batt? I dont want to pay $240 for it from the dealer!!!!
Is it possible to replace the VR without removing the alternator? Anyone know how to remove the alternator if not?
I had the battery message recently, and I took the car to Sam's and replaced the rear batter for $90 installed.
The front battery connection was a bit loose and I just used a wrench to make sure it was nice and tight. But I will replace soon, just in case.
No more messages.
I find it really alarming that the alternator would quit and shut down power to the car while driving.
Is there a way to tell which type of alternator is faulty (part #)? I'm sure if MB knew that people could get in serious danger with a part that might fail while driving, it would be considered a recall.
They went through the trouble of recalling a gas tank line that could crack.
While I don't dispute the alternator has caused issues to some members, dealers always want to juice the situation and charge for things that are related.
I just had a similar situation with my car. The message was polite intially (and not unsusual), for about a day and then today it got nastyand unusual; the display turned red, alternated beween the battery symbol and a message to stop driving the car/brake loss, alarm beeps went off and stayed on all the way to my mechanic. We checked both small and big batteries and found the former to be okay, but the latter had been drained (11.1 volts). We switched with a new battery in the trunk and the aggressive messages came back almost immediately. Further diagnosis suggests it the Voltage Regulator ($47.00) and not the alternator. The car should be done tomorrow and I will update at that time. Hopefully, it is that simple.
http://img19.imageshack.us/my.php?image=19109440.jpg
First they replaced the voltage regulator, but it had the same problem, so they replaced the entire alternator.
It ended up costing $1100, once again, thank god for easy care!!!!!
.....And if anyone was wondering, when the car notices that the alternator is going bad it raises the rev level at idle, so it feels like it is driving really rough...
I wish you were wrong, aleksander1099, but you are right. I replaced the rear battery no luck, then replaced the Voltage regulator and it seemed to work but 30 minutes later the messages were back. Now we are going to replace the Alternator. My original battery was still okay I guess, and but not the VR. I get my car back next wek Monday/Tuesday and I am sure I will be about 1500 lighter. Darn it!
How do we handle this on going???
