How to approach this problem
Old Mar 11, 2009 | 10:21 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Ok occasionally my SBC unit makes a vibrating sound. I have no warning lights on the dash. I know SBC parts have a 10yr warranty.
How do I present this problem to the dealrship so it can be fixed under warrant at no cost.
Old Mar 11, 2009 | 11:58 AM
Busta Riles's Avatar
1969 280S, 1991 300E
When i bought my 04 in October, one of the outstanding recalls was replacement of the SBC unit.
Correct, these components are covered for 10 years. If it is a recall, there is no 10 year restriction (ie: if car comes back after 15 years and recall was never completed, recall will be performed)
Why are you worried?
Old Mar 11, 2009 | 12:29 PM
shardul's Avatar
The unit is making a funny sound
Old Mar 11, 2009 | 11:46 PM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
Is it constant? Or only occasional vibrate with sound? Mine is does it every so often. Personally I'm not worried about it. There's 10 years of warranty on the SBC!
Old Mar 12, 2009 | 02:01 AM
Do you feel it in the brake pedal or do you hear it from the engine bay?
Every time i start my car and put it in reverse, i feel a vibration in the brake pedal for a second and hear a bit of a sound. I thought it was normal.
Old Mar 12, 2009 | 02:26 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Make sure you have the update, it is a bracket and a larger ground strap.
Dealer will do it for free.
Old Mar 12, 2009 | 03:22 AM
The Godfather's Avatar
4 wheeled car.
Everytime I step into the car (ie open the door w/ my key in the pocket -keyless go) I hear the SBC pump buzzing/pumping. At least that's what I think it is lol
Old Mar 12, 2009 | 03:25 PM
harjothundal's Avatar
05 e55
when you open the door, thats actually the airmatic pump leveling out the car... the sbc pump i believe is that slight vibration that you feel when pressing the brake pedel... i almost always get it after starting the car and backing out of the driveway...
Old Mar 12, 2009 | 03:28 PM
Does anyone else have this happen all the time?
Old Mar 12, 2009 | 03:43 PM
shardul's Avatar
UPDATE:
I took the car to the dealership and told them SBC unit is making a ratteling sound when i get the vibration on the brake pedal. they replaced the SBC hydraulic unit at no charge. Got an appointment the same day i called got a C300 as a loner. Way to go MB Sugar Land.
Old Mar 12, 2009 | 03:44 PM
shardul's Avatar
SBC recall was done on my car as per the VMI from MB
Old Mar 12, 2009 | 03:45 PM
shardul's Avatar
when ever you unlock the car after a long period the SBC system performs a wake up check so SBC pump also turns on.
Old Mar 12, 2009 | 07:20 PM
AZIPOD's Avatar
same here!!!
Old Mar 12, 2009 | 08:12 PM
05 e55
Originally Posted by shardul
UPDATE:
so is the vibration on the brake pedal normal? i feel/experience it every day...
thank you for the clarification!
Old Mar 13, 2009 | 04:39 PM
shardul's Avatar
Did a check on the SBC hydraulic unit they replaced 1400 dollars, thank god for the 10yr SBC warranty.
Old Mar 13, 2009 | 10:43 PM
htn's Avatar
htn
sl55
may I ask a dump question, wth is SBC?????
Old Mar 16, 2009 | 09:52 PM
shardul's Avatar
SENSOTRONIC BRAKE CONTROL
http://www.whnet.com/4x4/sbc.html
Old Jul 11, 2010 | 09:21 PM
pimpjuice's Avatar
2003 E55 AMG
Is this ten year warranty jsut for the original owner? Mine is a 2003 and it has started vibrating the pedal all the time but especially when I am slowing down then it quicks a second before the car fully stops.
