Can Anyone post PIC of Cooling Diagram from WIS
Can anyone post a pic of the cooling circuit for the E55 from the WIS.
Thank you |
Someone post any 63 diagrams! <3
is ours the bottom diagram?
Ours is the top (W211). The 220 is the S class.
Nah, bottom is either CL or S, I forgot which. Not sure why AMG put the larger heat exchanger in them and not us!! :X:X:X:X
**heh, jang beat me to it** |
Isint our coolant reservoir on the other side.
oh ok thanks!
i should have figured that out, model 211 refers to W211. so i guess that would be the same for the C219? so is part 110/11 the OEM Behr heat exchanger? |
Originally Posted by jikjak
(Post 3426081)
oh ok thanks!
a quick question when you turn the car on does the IC pump also start. The reason i am asking this is because when i put my CM30 pump and bleed the system i don't want to hook the CM30 pump to a 12v source in order to bleed the system.
I do not know what happens at startup but MB switched the temp at which the pump comes on back in an '06 ECU flash in an attempt to extend the life of the pumps.
Far as I know. Pump only comes on when needed. So under WOT and at cetain higher temps.
Not sure of the parameters of those, but clicking start on the key in the garage is not gonna turn her on. Sorry for the bad news. |
Originally Posted by Jakpro1
(Post 3427513)
Pretty sure. Anyone have any addit info?
Mine is hooked up to run all the time so I had forgot about that with the stockers. |
(Post 3427622)
Regardless of how the pump is activated, it’s imperative to properly evacuate all the residual air from the intercooler core in order to maximize its effectiveness.
Because the intercooler is at the uppermost point in the fluid circuit, it’s a naturally-occurring airlock. MB’s workshop procedure necessitates closing off the core’s return hose – downstream of the vent nipple - to properly bleed the system. The resultant backpressure/restriction forces any trapped air from within the core. I use a Quick Grip clamped on the hose. Alternatively, a hose clamp can be affixed to serve the same purpose, even while you’re underway. http://i209.photobucket.com/albums/b...MG/ICfluid.gif http://i209.photobucket.com/albums/b...oolerbleed.jpg |
