My SL65 is broken
Old 05-17-2009, 11:46 PM
Akademiks's Avatar
SL600
My SL is broken too apparently.
Such a load of crap.
Old 05-18-2009, 09:40 AM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Originally Posted by bfnnrgn
Piece of junk. Still not running right. Though it's better than it was before it's still not near where it was. It's still pulling timing or dropping boost mid run. I data logged the dyno pulls this time. IATs are starting right at 70C, briefy dropping to low 60's before jumping up into the high 70's before it's done. Not exactly a hot day out either.
Is there any other things I should have them look at? They already replaced the IC pump. It seems like the IC pump isn't running unless it's under load. At idle with 2 fans on it the IAT was in the 70s and inching higher. It wasn't until it got going on the dyno that it briefly dropped.
I am sorry that. You might want to try and replace stock Bosch I/C pump with a Johnson CM030 and set the pump to run all the time (ignition on).
Tom
Old 05-18-2009, 10:08 AM
Razorecko's Avatar
wouldnt hurt to check over the entire fuel system / pump/injectors/rails
Quick Reply: My SL65 is broken
