Best Heat Exchanger - E55.....
E55 then E63, now back to an E55
I know there are numerous topics.....
Best friend wants one-
Just looking for a quick summary //
Code 3 or LET ?
Thanks in advance......
Code 3 or LET ?
im looking for one as well. probably LET.
something with dimensions of 30 x 6 x 3 inches
im also thinking of getting one of these, just waiting for them to get back to me.
http://www.bellintercoolers.com/pages/LAMain.html
E55 AMG
I have the LET on my car with the cm30 pump and I live in south florida and my s/c has never shut down on me and runs as consistant back to back even in the hot humid weather down here..my car also has the big asp pulley
Here's my $.02:
![](http://www.rpmoutlet.com/images/mtb980046.jpg)
http://www.rpmoutlet.com/03cobraheat.htm
I should add that they're not "made" for Mercedes applications, but they can be made to fit pretty easily.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I believe this to be true as well.
Here's my $.02:
Here's my $.02:
Any of them should do the trick, LET, Code 3, and the ones from other tuners as well. It's best to put in the Johnson CM30 Pump and also do a Thermostat with -10 mod as well. Better cooling=better and more consistent operation for the 55K Cars.
Here's my $.02:
Here's my $.02:
But for faster and better CS at the moment go with LET.
2005 Crossfire SRT6
Check www.frozenboost.com and measure one out that fits best. Don't be surprised if wire ties are required for proper fitment. A shop can always weld mounting tabs if you need them.
What is a thermostats with -10 mod? I know a lower temps thermostat can be put in (same as my procharged z06 running a 160 tstat.) But what degree tstat run on the 55k cars, and better yet what is the -10 mod?
2003 cl55 (sold)
2003 cl55 (sold)
another issue on the frozen boost h/e is that the inlets and outlets are female. so you will have to get a barb to turn them into male which may reduce the ID on the inlet and outlet.
2003 cl55 (sold)
