E63 headlight conversion
Old Apr 8, 2009 | 03:34 PM
justans10's Avatar
Nothing special
Hey, I just got a set of E63 headlights for my 06 E55, and was wondering if anyone knew what the parts numbers were for the E63 headlight plugs (on the chassis)? I called the dealer and was told I have to order an entire front engine harness for them, but I do not buy that. They also claimed that the headlight repair kit does not contain these plugs. Thanks for any help.
Edit: Come on, 45 views and no one knows? Is there anyone out there that can help me?
Old Apr 9, 2009 | 12:55 AM
Max.H's Avatar
E55
go to a junkyard and get used clips from an 07 and up e350.
Old Apr 9, 2009 | 09:06 AM
Absolutt's Avatar
E55 AMG
I heard that you couldn't do it, something about the features of the headlights are different then the e55's.
Old Apr 9, 2009 | 09:11 AM
justans10's Avatar
Nothing special
I've seen the swap done before, so I doubt it, unless someone used all the E63 reflectors and used E55 circuitry.
Old Apr 9, 2009 | 09:40 AM
Absolutt's Avatar
E55 AMG
Google "e63 headlight conversion" I've read you have to get the clips and still change pins around inside it, and then something about the self leveling still not working. I considered changing my headlights, someone had a pair of xenons w/ the ballasts for 250 shipped on the forum (2 mounting clips were cracked off). Thought about just changing the reflectors, but didn't want to mess them up and have 2 sets of useless headlights.
Old Apr 9, 2009 | 11:33 AM
jamusa's Avatar
My 03 e55 was changed to a xenon from an e63... my mechanic got everything to work but the leveling.
Old Apr 9, 2009 | 01:29 PM
justans10's Avatar
Nothing special
Is there any way you can get a part number on those plugs from him? I'd really appreciate it.
Old Apr 9, 2009 | 01:41 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
I thought a few guys on the forum did the conversion before?
Old Apr 9, 2009 | 01:50 PM
bobgodd's Avatar
2004 E55
I like the new look headlights much better than the ones on my E55. I would love to do the conversion one day, however if I lose my active leveling/cornering I don't think it would be worth it for just the look alone.
jamusa's Avatar
I will ask my mechanic as soon as i get a chance to.
Old Apr 9, 2009 | 09:18 PM
Max.H's Avatar
E55
I heard you can change out the lenses to the new ones.
bobgodd's Avatar
2004 E55
Well that would be the way to go! The only thing better is the look anyways
Old Apr 10, 2009 | 01:25 PM
justans10's Avatar
Nothing special
I think I got the plugs, we will see tomorrow when it comes into the dealer (don't want to list part numbers until I'm sure it works), but I still need pins. Does anyone have the pin out for the E55 and/or the E63?
Old Apr 13, 2009 | 12:27 PM
justans10's Avatar
Nothing special
Well, update on this. I got the plugs and pins, but I am still waiting on a wiring diagram. The plug part numbers are 211-545-11-28 and 023-545-06-26 respectively (you will need one of each per light). The pin part number is 000-540-38-05, and you will need either 16 or 18 (8 or 9 per side) to complete the conversion (waiting on the wiring diagram to confrim, but since there are only 8 wires per side on the 55, I'll go towards saying it'll probably only need 16). There is probably a cheaper part number to get these pins, but this one works, so I used it.
Old Apr 13, 2009 | 12:41 PM
bobgodd's Avatar
2004 E55
Thanks for the part numbers and the update, keep us posted
Old Apr 13, 2009 | 05:02 PM
justans10's Avatar
Nothing special
I actually forgot to count one plug on the 55. The grand total is 11 wires on the 55 and 9 on the 63, per side. We will see what happens.
Old Jul 9, 2009 | 07:51 AM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
do you have the wiring diargram or schematics for the e55 headlights?
thanks
Old Jul 9, 2009 | 09:40 AM
justans10's Avatar
Nothing special
thanks
Unfortunately I ended up tossing it. We ended up swapping the reflectors and lenses from the 63 lights to the 55 lights. The turn signal bulbs did not quite line up, but it is hard to tell without knowing what to look for. We also swapped the LED parking lamps over with resistors.
Old Jul 9, 2009 | 02:21 PM
MB_Forever's Avatar
I didn't know the conversion was such a pain?????
Old Jul 9, 2009 | 02:36 PM
JoelE55's Avatar
07 E63 AMG / 07 C230 / 14 E350
It is especially for MB..it's cheaper to purchase the car that has all the goodies...IMHO
Old Apr 27, 2012 | 08:39 PM
IMRANW211's Avatar
e class w211
can you please help me do this conversion
Old Apr 27, 2012 | 08:54 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
You should have gotten the eBay headlights that look like e63 ones
Old May 13, 2012 | 07:49 PM
IMRANW211's Avatar
e class w211
can you please tell me what resistors to use as im having trouble with my one as they keep blinking and not working thank you
Old May 13, 2012 | 08:22 PM
moosejaw's Avatar
none
What's the advantage or reason people want to upgrade to the E63 lights?
Old May 13, 2012 | 10:43 PM
wally AMG's Avatar
MB
You need star diagnostic system to tell your ECU to recognize zenon lights, after this process your headlights will stop to blink.
