Value of 2006 CL65
http://www.autotrader.com/fyc/vdp.js...e&rdpage=thumb
Honestly, I wouldn't waste my time with that one. The price is so far from reality that you'll never be able to negotiate them down to where it should be. This is one of those where they'll need to sit on it for a year while it loses an extra $10k or $20k, before they realize their mistake and price it at market. Unfortunately I think the 65 people are just in shock and/or denial at the depreciation on their cars. That thing was like $200k 4 years ago. Hard pill to swallow, but time marches on, and "it is what it is".
Anyway, CL65's and S65's are all over the place in the $40k's. Check eBay and autotrader. Also, white is not the most flattering color for a CL anyhow.
http://www.autotrader.com/fyc/vdp.js...standard=false
This one's pretty nice too:
http://cgi.ebay.com/ebaymotors/2006-...3A1|240%3A1318
There's no difference between the 05 and 06 models that I'm aware of, and the 05's are still plenty new enough to get an extended warranty. Given the insane depreciation curve on these, it prolly makes more sense to get an '05.
The Renntech car 2006 with low miles above is $82,600, saw the price on Auto Trader. That will never happen for the seller. Just unbelievable.
These things depreciate like $30k/yr, it really makes more sense to go with the '05 if you can find one in your mileage range. Also, I wouldn't even bother looking for an MB CPO one, the dealers are downright delusional when it comes to 65's. Every one I've ever seen on a dealer lot is insanely overpriced, they'll want like $80k+ for a 2005.
The extension runs from the date the car is CPO'd, and even though the T&C sometimes states "From In-Service Date", the dealers have flexibility with determining that calculation. When I was car shopping a year ago, I was running into 2001's and 2002's that were CPO'd on dealer lots and were eligible for extensions. I think the actual hard "rule" for the dealers is that the warranty extension can't take it past 10 years from the in-service date under any circumstances, and the car can't be entered into the CPO program after 7-years from the in-service date. It's something along those lines.
I looked at a 2002 S55 (the non-s/c one) at Brumos about a year ago that was CPO'd and eligible for the 3-year extension, so a 2005 will be no problem whatsoever.
Remember, the most you're EVER going to get out of the CPO program is 3 years anyway, since that's the max extension period they offer. If you buy a 2005, you're getting a max extension of 3 years. If you buy a 2006, you're still getting a max extension of 3 years, plus whatever couple months' worth of original factory warranty is left. And the 2006's are coming off factory warranty coverage right about now anyway, so you're going to be in the exact same boat regardless of whether you go with a 2005 or a 2006, since either way it's going to be 3 years from the date you bought it.
To get any more than that, you'd have to buy a 2007 or a 2008, so that you get a year or two of the factory warranty left and then the CPO warranty starts after that expires. That would give you 4 or 5 years, but then you'll be paying $100k for the car. If you're looking at a 2005 or a 2006, then either way your warranty period is going to be limited mostly to the CPO coverage, which gives you 3 years either way since both of those years are mostly out of warranty now. See what I'm saying? Might as well get the discount on the purchase price...
Anyway, you were saying that the white CL65 was overpriced at $60K and it had low miles, as well. I would just like to know what to pay for either an '05 or '06 with miles below 30K. Just a guideline or range is all, what do you think? Also its not all about money when you find a clean car that you like so a few thousand is well expendable.
I've seen CPO'd cars that were well outside of the time period where the original 4-yr warranty could possibly still be in effect. For example, take 2004's, most of them went into service in 2003 and their factory warranties would have expired back in 2007 or 2008 at the latest, but there are still a lot of CPO'd 2004's around.
The dealers can CPO a car out of the factory warranty period, subject to some guidelines. I'm pretty sure the cutoff is that the time has to be less than 7yrs from the in-service date for them to enroll it in CPO, and then regardless of the year of the car you can only extend the CPO coverage out to a maximum of 3 years.
So with these CL65's, the 2006's will have mostly gone in service in 2005, and will be coming out of warranty right about now. The 2005's will have mostly gone in service in 2004 and will already be out of warranty. You can pick up either a 2005 or 2006 as a CPO car, but either way all you're really going to get is the max 3-year CPO extension because there's no real factory warranty time to speak of remaining on either of those years.
What I'm trying to say is, regardless of which year you pick between an '05 and an '06, you're going to wind up with the same 3 year warranty if you're looking at an MBCPO vehicle. So with that said, you may as well get an '05 since these things depreciate like rocks and you'll save like $20k-$30k on the purchase price, and get the same 36mo/100k warranty coverage either way.
As to that white 2006, I think that was definitely on the high side, but the 2006's are worth more than the 2005's because they haven't had as much time to depreciate. That's why I'm harping on getting a 2005, because there were no changes between the years that I know of, and the purchase prices are so hugely different. You can't probably pick up a low mile CPO'd 2005 and buy the 3yr CPO warranty extension and still be out the door for <$50k-$55k. No way you're going to swing that on a 2006.
And what I'm saying is, if the 2006 CPO CL65 has a couple months worth of factory warranty remaining, and the 2005 CPO CL65 will only have the 3yr extended coverage in effect from the date of your purchase, then you'll have about the same warranty remaining on either vehicle. All you're getting "extra" on the '06 is the couple months that will still be outstanding on the factory coverage. I don't know that 3-6 months worth of extra warranty coverage is worth the $30k price difference between the model years.
I absolutely 110% guarantee you the car does NOT have to still be within the original factory warranty period in order for a dealer to enter it into the CPO program, as long as the car is in inventory at a franchised MB dealer and the vehicle meets all the other criteria.
Do a search on MBUSA.com for E55's as an example, you will see multiple 2003's, 2004's, and 2005's, all of which would be out of factory warranty by now, yet they're still CPO cars with a 12mo warranty, and eligible for the optional extensions.
With every Certified Pre-Owned Mercedes-Benz comes peace of mind, because every MBCPO vehicle is backed by one of the most comprehensive pre-owned vehicle limited warranties available.
For starters, any remaining portion of the Mercedes-Benz four-year/50,000 mile* New Vehicle Limited Warranty applies to the vehicle. After that, MBCPO Limited Warranty provides comprehensive vehicle for another 12 months, or up to 100,000 total accumulated miles.* For those MBCPO vehicles that are no longer covered by the New Vehicle Warranty, the MBCPO Limited Warranty takes effect at the time of delivery.
This coverage extends to the engine and powertrain, steering, suspension, brakes (excluding wear of discs and pads), electrical system, climate control system, and more.**
* Whichever comes first.
** Please see your Mercedes-Benz Dealer for a copy of the Mercedes-Benz Certified Pre-Owned Limited Warranty.
That is nice to know. The problem: we have to get the car from a MB stealer or buy and existing car with a CPO warranty. Plus pay the stealer for the warranty. 3 years is what $6K or more??? One reason for the Mercedes Benz dealers all around charging prices north of reasonable for these rides.
Tom
Tom
I really think your best bet is to buy a CPO'd 2005. It may be slightly more than a regular 2005 CL off eBay or whatnot, but you'll still be saving MAJOR money over a 2006, which is what you were considering in the first place. But you still get a factory warranty.
It'd be the best of all worlds.
