E63 Problem!
Old Apr 27, 2009 | 01:52 AM
aguita's Avatar
AMG
E63 Problem!
Hello
I have a friend that owns a E 63, Yesterday we went to the track for the 1st time to do some time attack and for some reason when the car was Put in Manual to use the paddles after a couple of mins the car went to C/S and if you press the button no matter what It wont go to Manual again..
Also to completly disable the ESP do we need to do the cluster disable or theres another way? thanks
Old Apr 27, 2009 | 04:29 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
That problem is uncommon, but known. Sometimes theres an intermaitant fault with the engine oil temp sensor which blocks manual mode. A new sensor is available.
You need to disable ESP via the clustor. Short of doing skid pan days, there's no need to disable ESP, just ESP off should be enough for a track day.
